2013 road glide steering bearings - Road Glide Forums
post #1 of 3 (permalink) Old 01-08-2017, 08:57 AM Thread Starter
Is the lower steering stem bearings pressed on? Getting ready to pull it apart and the service manual does not call out for a puller to remove the bearing. Simply says remove the bearing. Thanks
Slider1156 is offline
post #2 of 3 (permalink) Old 01-08-2017, 11:31 PM Thread Starter
It is. Made a puller
post #3 of 3 (permalink) Old 01-09-2017, 07:39 AM
FastHarley's Avatar
Bearing puller
I do many. Almost (99.999999%) have the inside race rusted/corroded onto the steering stem. You can get them off sometimes using a sort of pry that is clamped than tightened onto the underneath of the bearing to wedge the bearing off on its ramp system. Do not rely on the thought that your bearing will come off of the steering shaft unless you are very lucky and your bike or bearing assembly is somewhat new. Good luck.
FastHarley is offline
Violent Front End Steering and Handlebars Shaking on My CVO Road Glide Ultra 2011 CVO RG Troubleshooting for Road Glides 74 07-25-2017 11:45 PM
wobble - steering bearings? xbmxxx *General Road Glide Discussions/Pictures 23 09-28-2014 08:51 PM
steering head neck bearings ATTN!!! jaysrgu *General Road Glide Discussions/Pictures 27 07-05-2014 01:44 PM
2011 Road Glide steering head bearings bradj *General Road Glide Discussions/Pictures 5 02-12-2011 12:35 PM
2011 Road Glide steering head bearings bradj *General Road Glide Discussions/Pictures 0 02-11-2011 09:27 PM
