New suspension front/rear - Road Glide Forums
 7Likes
post #1 of 15 (permalink) Old 01-22-2017, 06:06 AM Thread Starter
Freaky's Avatar
Since the weather was decent (dreary, but in the low 50's today) here today, a couple of my buddies showed up and we installed some new suspension components on my bike (mine's an 09, fyi).
Put Progressive HD Springs in the front end (standard height) with Screaming Eagle fluid and Progressive HD 412's on the rear. Install was pretty straight forward, only glitch we had was getting one of the forks to drop out, seems that corrosion/rust had settled in some and made it a little difficult to remove, but she finally came out. The old fluid that was in the shocks was in need of replacement for sure, was very thin and looked like burnt motor oil in color (I am told that new it's a reddish color ?). As of now I have the rears set at the lowest point until I get the chance to ride it some and adjust as needed. Got it all put back together and wiped down and back under cover for a bit more time. I did not get the chance to ride it, as the fog set in and it was so damp out there with all the cinders on the road, just not a good recipe for a ride at all. I believe there are probably better upgrades that could have been made, but those would have cost a lot more money. I am simply hoping for some great improvements over what my stock set up was and I believe I will have that now.
Anyway, there was a post earlier that I read that indicated you could change out the springs in the front forks without removing them from the bike, this is simply not true, there is no way you could do that. Removing them was not a big deal, just took a little time.
I will report back on what I think of this set up once we get through our winter and I am back riding.
08Zinc and Nordic Berserker like this.
Freaky is offline
post #2 of 15 (permalink) Old 01-22-2017, 07:22 AM
eddienelson's Avatar
Im excited for you. A suspension upgrade is on my list of things to do. Good luck and hopefully you'll get to ride it soon.
2016 RG Custom Vivid Black
eddienelson is offline
post #3 of 15 (permalink) Old 01-22-2017, 08:26 AM
FLTREX's Avatar
I had a pair of 12 " 412's on my 93 FLHS with -1 Progressive springs up front , made for a better ride than the stock set up for sure. On my 15 RG I replaced th rears with 12.5" Progressive 444,s and like them alot ,thinking about Ricor intiminators or Race Tech gold valves for the front. I think you will like your improved suspension.
FLTREX is offline
post #4 of 15 (permalink) Old 01-22-2017, 03:48 PM
mfgator's Avatar
Doing the same next couple of weeks. Adding super shox on the rear and mono tubes -1 in the front. Looking forward to the ride improvement. Mine is an 09 orange.
Let us know how she rides when the weather clears up.
08Zinc likes this.
mfgator is offline
post #5 of 15 (permalink) Old 01-22-2017, 06:27 PM
007xd9's Avatar
I am going to do the Progressives on the front next week. I can't wait to hear how your bike rides.
007xd9 is offline
post #6 of 15 (permalink) Old 02-11-2017, 09:25 AM Thread Starter
Freaky's Avatar
Have not had any chance to get out and try the new set up yet, but I did forget to mention that my bike came with 13" rears and I put 13" on, but the bike had to be raised up about 1/2" more for the new ones to fit. I have read that HD's are not a true 13" but rather about 12.5", and I would believe this after doing my own swap.
Freaky is offline
post #7 of 15 (permalink) Old 02-11-2017, 10:12 AM
Nordic Berserker's Avatar
Exact setup I have on mine 👍🏻
Nordic Berserker is offline
post #8 of 15 (permalink) Old 02-11-2017, 11:11 AM
VikingRider's Avatar
...(mine's an 09, fyi).
Put Progressive HD Springs in the front end (standard height) with Screaming Eagle fluid and Progressive HD 412's on the rear....
Which SE fork oil did you use? I guess it's the Performance and not Racing.
Here are the numbers (weight and viscosity ((@212F/100C)):
Harley Type B
10wt – 5.51
Harley Type E
20wt – 7.95
Screaming Eagle Performance (Heavy)
20wt – 8.60
Screaming Eagle Racing (Extra Heavy)
60wt – 24.49
I tried SE Heavy on my bike - too hard, felt like the whole triple-three was squeaking when hitting a pothole...
The E was heavy enough for my type of riding (riding the twisties rather than the highway). JMO
FLTRSEI2
VikingRider is offline
post #9 of 15 (permalink) Old 02-11-2017, 03:40 PM Thread Starter
Freaky's Avatar
Harley Type B
10wt – 5.51
Harley Type E
20wt – 7.95
20wt – 8.60
60wt – 24.49
Not the racing one, just the SE Heavy.
Freaky is offline
post #10 of 15 (permalink) Old 02-11-2017, 06:00 PM
08Zinc's Avatar
Another here with that setup, except I added True-Track. Very happy with mine so far.
Blessings, Zinc -
08Zinc is offline
Front and Rear Suspension Setup dinggus Suspensions 29 03-16-2017 02:56 PM
2017 M8 SUSPENSION FRONT AND REAR Questions ynotbmester General Off-Topic Discussions 11 08-31-2016 02:45 PM
Front and Rear Air Suspension Q-Hog Suspensions 15 09-26-2014 12:49 PM
Front and Rear suspension OneSlickGlide Suspensions 12 07-29-2013 09:10 PM
New Progressive suspension front & rear. TRUBlue Suspensions 16 04-18-2013 09:29 PM
