Ohlins fork kit - Road Glide Forums
 6Likes
  • 1 Post By tj316
  • 3 Post By FastHarley
  • 2 Post By SmokeyJoe
post #1 of 8 (permalink) Old 01-26-2017, 04:24 PM Thread Starter
Ohlins fork kit
Ok guys has anybody had Howard set up there road glide with Ohlins FKC - 102
dozer23 is offline
post #2 of 8 (permalink) Old 01-26-2017, 08:33 PM
SmokeyJoe's Avatar
He did a fantastic job on my 2012
SmokeyJoe is offline
post #3 of 8 (permalink) Old 01-27-2017, 03:10 PM Thread Starter
Wow I can't believe no one is using this up grade? Smokeyjoe your forks must have Howards 30mm. Kit ?
dozer23 is offline
post #4 of 8 (permalink) Old 01-27-2017, 04:05 PM
SmokeyJoe's Avatar
Mine are the standard size that come on the 2012 models, not sure what size that is... I did not upgrade any tube diameter's
post #5 of 8 (permalink) Old 01-27-2017, 08:09 PM
tj316's Avatar
I've got the 30mm cartridges inside the 49mm forks on my 2011, it is great
FastHarley likes this.
tj316 is offline
post #6 of 8 (permalink) Old 01-27-2017, 11:14 PM
SmokeyJoe's Avatar
Is that what the stock sizes are?
post #7 of 8 (permalink) Old 01-28-2017, 12:19 AM
FastHarley's Avatar
stock size
Your forks are 41mm. 1948 (first year of the HydroGlide) to 2013 are all 1 5/8" AKA 41mm (which they are not) and 2014 ~ current is 49mm. This applies only to FLT's as this is that type of forum. Your forks were purchased from another vendor and you were unhappy with the results. I was sent the forks after being re-built from OhlinsUSA where you were still unhappy with the results after raising your performance objections. I took your forks apart when I received them and took apart your 25mm FKC-101 cartridges, cleaned, resurfaced your main piston(s) than re-valved them for your taste. I than sent them back to you.
The reason why this was such an easy job for me is because this member accurately described what he felt on each part of the road imperfection (either pot hole of speed bump) so I can "see" than correct his problem. Easy when working with knowledgeable bikers and makes me happy to get a smile from another happy biker.
25mm cartridges were designed for the 41mm fork tube because of the tight I.D. clearances. A 30mm NIX needs at least a 43mm fork tube which is why all 49mm forks are a good candidate. A 30mm cartridge will not fit inside of a 41mm fork.
tj316, eddienelson and BG1960 like this.
FastHarley is offline
post #8 of 8 (permalink) Old 01-28-2017, 06:58 AM
SmokeyJoe's Avatar
I can never pass up an opportunity to thank Howard enough! The ride difference is night and day after Howard reworked/tuned them for me. I was so close to throwing them.out and starting over the. Howard offered to help me out.
tj316 and eddienelson like this.
Ohlins HD 357 vs Ohlins HD 022 mach65 Suspensions 8 09-08-2015 10:54 PM
hd lowering Cartridge Fork Kit or progressive lowering kit IranAround Suspensions 11 03-21-2015 12:09 PM
Racetech Fork Suspension and Lowering Kit TracyB Classifieds Archive (3 months old+) 9 02-20-2012 05:37 PM
For Sale: Chrome Fork Slider End Cover Kit ScooterDog Classifieds Archive (3 months old+) 2 02-10-2011 10:48 AM
