Tracking to the left... - Road Glide Forums
 5Likes
post #1 of 11 (permalink) Old 03-24-2017, 07:12 PM Thread Starter
Hotwire's Avatar
So, I swapped out my front wheel and tire with new, I also removed and replaced the front shocks.
I have replaced everything according to the service manual, torqued and measured. But...
If I put both hands up on the road, the bike leans to the left and very slowly tracks left.
any suggestions?
- Arte Et Marte -
Hotwire is offline
post #2 of 11 (permalink) Old 03-24-2017, 07:26 PM
staush's Avatar
tracking
front and rear wheels aren't in line. which one ????
staush is offline
post #3 of 11 (permalink) Old 03-24-2017, 08:22 PM Thread Starter
Hotwire's Avatar
I only removed the front. I replaced it with a road glide special wheel. And everything went back in the same way it came off.
Hotwire is offline
post #4 of 11 (permalink) Old 03-24-2017, 08:38 PM
You may of binded the forks when you reinstalled them.
post #5 of 11 (permalink) Old 03-24-2017, 08:39 PM Thread Starter
Hotwire's Avatar
Like installed crooked?
Hotwire is offline
post #6 of 11 (permalink) Old 03-24-2017, 10:00 PM
twowheeladdict's Avatar
I haven't worked on the Road Glide yet, but on previous bikes you have to tighten everything in a specific order and put a block in front of the tire and pump the suspension a few times without applying the brakes before making the final torque on certain fasteners to allow everything to align.
Also, make sure you don't have the bike loaded unevenly. just 20 lbs in one saddlebag can make the bike pull. Also, not sitting squarely on the bike can cause it to pull one way. Good luck.
ironmark, RGKen, Smarty and 1 others like this.
twowheeladdict is offline
post #7 of 11 (permalink) Old 03-24-2017, 11:58 PM
UT_Larry's Avatar
If your rear shocks are independently adjustable, both not being adjusted the same could cause it. Possible fork seal leak, on one fork. Either case would cause a different compression on the shocks causing a weight unbalance. Similar to uneven loads in the saddle bags.
UT_Larry is offline
post #8 of 11 (permalink) Old 03-25-2017, 12:38 AM
RonC26's Avatar
Mine tracks differently all the time - I assume because of loading the bags differently. Don't forget the crown of the road can pull you also, though I'd expect that to pull right. If it's a big change you might have something torqued/aligned wrong.
ďA ship in harbor is safe, but thatís not what ships are built forĒ - John A Shedd
RonC26 is offline
post #9 of 11 (permalink) Old 03-25-2017, 04:02 AM
RFG7680's Avatar
My 08 SG did this from day 1. Even after I had the front end chromed and lowered.
RFG7680 is offline
post #10 of 11 (permalink) Old 03-25-2017, 05:07 AM
In my view it could be one of the fork legs not completely vertically aligned with the other, even 1 or 2 millimeter of difference might cause the problem.
On tourers the rear tire is always aligned thanks to the registration cam, while front and rear are factory aligned and you do not to mess with it unless you have a bad crash.
Another possibility is that the new front tire was badly stored (horizontally instead of vertically with a pile of tires over it) and that might have cause a profile permanent distorsion
Beaver is offline
satellite tracking devices jrbean1 Road Trip Discussions/Stories/Pictures 11 06-04-2014 07:12 PM
Covert cell phone tracking app? Magnum General Off-Topic Discussions 19 02-11-2014 08:59 PM
GPS Tracking for Friends and Family Brewiz ARCHIVES-SWIII St. George, UT 6 07-14-2013 12:45 PM
Going left..... Way left! DarbinCo Troubleshooting for Road Glides 13 09-20-2012 10:16 PM
Gps tracking solutions BLACKHAWK *General Road Glide Discussions/Pictures 1 02-28-2012 08:43 PM
