Anyone With Front MM Ohlins 30mm?s - Road Glide Forums
post #1 of 2 (permalink) Old 04-19-2017, 08:48 PM Thread Starter
MisterEd's Avatar
Looking to see if any modifications are needed to the housing assembly that is on the tops of the front forks using Howard's 30mm Ohlins. Where the compression and rebound adjusters are.
Thanks
MisterEd is offline
post #2 of 2 (permalink) Old 04-20-2017, 06:34 AM
tj316's Avatar
You don't need any modifications they fit under it fine
tj316 is offline
Ohlins 30mm cartridge now clunks Ratdog33 Suspensions 20 12-10-2018 11:47 AM
Ohlins HD 357 vs Ohlins HD 022 mach65 Suspensions 8 09-08-2015 10:54 PM
Fork oil 2014 street glide with 49 mm front legs JPROADGLIDE Fluids and Lubricants 2 11-21-2014 12:37 PM
MM EFI to Carb Conversion for a '01 RG v-rodder *General Road Glide Discussions/Pictures 10 05-19-2011 10:37 PM
MM Injection BIGMO ECM/Fuel Management systems 7 07-29-2010 09:37 AM
