Swing arm bushings - Road Glide Forums
post #1 of 1 (permalink) Old 04-26-2017, 06:40 PM Thread Starter
Clutch1's Avatar
Swing arm bushings
I replaced the swing arm bearings and bushings as well as the belt and pulleys. I am having difficulty getting the bushings right. I have followed the manual each step. I am still almost an inch too wide to get the plates on either side bolted up.
I have to be missing something here. Everything seems good but I cannot get the plates to go on. I got one on and it pushed the other side out. Now to get it all back in line again.
Somewhat lost lol.
Chuck
Clutch1 is offline
Swing Arm Bushings and Motor Mounts hotrodad Suspensions 15 06-14-2016 09:46 PM
Swing arm bushings/engine mount problem ?? 93-331-29psi Troubleshooting for Road Glides 38 10-26-2015 08:27 AM
Swing arm cracked!?!? Fenny Suspensions 26 10-14-2013 05:35 PM
swing arm torque kentucky cowboy Troubleshooting for Road Glides 3 03-15-2013 07:44 PM
rust at rear swing arm from under belt guard. jeff Road Glide Specific Discussions 5 07-04-2011 11:22 AM
