Monotube clunk - Road Glide Forums
 4Likes
  • 1 Post By sgtdills
  • 1 Post By mastergunnera8
  • 1 Post By rlaf75
post #1 of 10 (permalink) Old 09-13-2017, 07:13 AM Thread Starter
Monotube clunk
I notice lastnight on my way home from work the I had a clunk from the front end of the bike. I had to make a hard stop at an intersection so the forks were compressed. After the bike settled I grabbed the front brake lever and pushed the bike while still on it to load and unload the forks. I installed progressive monotubes approximately 2 years ago and this is the first time I noticed the clunk. Has anyone else ever notice anything like this with the monotubes?
post #2 of 10 (permalink) Old 09-13-2017, 04:09 PM
sgtdills's Avatar
I had that before. But my neck bearing spacing needed to be adjusted.
rlaf75 likes this.
sgtdills is offline
post #3 of 10 (permalink) Old 09-13-2017, 08:40 PM Thread Starter
I will check that. Thanks
post #4 of 10 (permalink) Old 09-13-2017, 08:43 PM
mastergunnera8's Avatar
I have a clunk when the forks are unloaded...topping out..hate it..dealer said, guess what?..."its normal"...I think the small top out springs were either left out or installed worng..but I aint payin that much to find out!!
rlaf75 likes this.
mastergunnera8 is offline
post #5 of 10 (permalink) Old 09-13-2017, 10:16 PM Thread Starter
Yeah I wouldnt pay anyone to do it either. I'll be doing it myself. Since I bought the bike new and I never adjusted the neck bearings before and since it's got about 52k on it I'll start there.
madmat likes this.
post #6 of 10 (permalink) Old 09-14-2017, 09:06 AM
bless0's Avatar
I am having the same issues with my progressive monotubes. Can someone explain to me how to check the neck bearings and how to adjust them if needed.
bless0 is offline
post #7 of 10 (permalink) Old 09-14-2017, 09:47 AM Thread Starter
Pick yourself up the service manual. It will show you the procedure to check it. You'll need to get the bike on a jack so the front end can swing freely. It goes by the number of "swings" the fork have when you hold the forks all the way to the left stop and release it. I believe it should move between 3 and 4 swings and stop somewhere close the center. Again the service manual will explain exactly
post #8 of 10 (permalink) Old 10-07-2017, 07:44 PM
I believe for rushmores its 1-1.5
and reduced from the original 3-4 for the older models..Im too lazy to go dig out my service manual..its an easy thing to do though...i went to home depot and got a long piece of flat steel stock and bent it slightly..worked great..
MightyWhitey likes this.
post #9 of 10 (permalink) Old 10-09-2017, 08:38 AM
Desertwndrr's Avatar
You are going to hear and feel some minor thud when the forks transition between the support spring and the top out spring. If the top out Springs were missing you would feel a very solid metal to metal bang as the forks extended.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #10 of 10 (permalink) Old 10-10-2017, 11:04 AM
Thats what I hear/feel...
Progessive Monotube Clunk watsondog Suspensions 8 05-06-2014 07:53 PM
monotube clunk? SIG556 Suspensions 3 05-04-2013 08:53 PM
Clunk Sancho Troubleshooting for Road Glides 27 07-17-2012 07:33 AM
Flexing front end clunk issue joke Troubleshooting for Road Glides 3 04-04-2010 08:05 AM
Annoying clunk/rattle over bumps from front end GizmoGlide *General Road Glide Discussions/Pictures 17 04-01-2010 03:15 PM
