modify premier shocks?? - Road Glide Forums
post #1 of 4 (permalink) Old 09-19-2017, 10:54 AM Thread Starter
Slimboybinz's Avatar
my RGS has premier shocks.
my problem is that i am fat and with my leathers and weighing the saddlebags the total weight to 152 kilos (0ver 350 lbs).
needless to say i bottom out going over a matchstick, even when the preload is set to max.
has anyone tried putting a stronger spring into the standard premier suspension??
Any thoughts..
Slimboybinz is offline
post #2 of 4 (permalink) Old 09-19-2017, 11:55 AM
mastergunnera8's Avatar
The problem is you have the 12 low shocks... you can either get the 13 inch... or go aftermarket, maybe a 13.5 that will give you more travel and have them setup for your weight. Heavy springs valving etc. several companies out there ... ohlin, pro- action, progressive etc... give em a call... you're not going to get anywhere with what you have unfortunately. Look in the forum sponsors area ... should have something there...
mastergunnera8 is offline
post #3 of 4 (permalink) Old 09-19-2017, 02:32 PM
Laconia's Avatar
I have SuperShox 14" Premium - great product - great ride - and as already mentioned you can only expect so much from a 12" shock - don't know why HD used it on the glides should never have gone below the 13" - the SuperShox Premium does not change the road height - it adds and extension, giving you the 14" of travel that two inches makes a lot of difference - I had the same problem as you are having - it cleared up completely with them.....
2017RGS, Vel Red, Stage IV, HD Performance Exhaust, HD Tuner, SuperShox Premium 14", HD Tall Boy Bars, Lepera Daddy Long Legs, HD Cool Fan, EZ-Up, 15" Smoke Windshield, Rear Saddlebag Guards, LED Lighting,Passenger Floor Boards, Whim,
Laconia is offline
post #4 of 4 (permalink) Old 09-19-2017, 04:06 PM
Any thoughts..
'Have the HD Premium stuff Front & 12"Rear on "The Short Bus" we weigh in at 420lbs + gear, do not bottom out very much at all, preload on shocks is not maxed out...
Maybe something is wrong / worn out with your suspension??
HeatWave is offline
Modify or not Modify, that is the question Simpleman1025 *General Road Glide Discussions/Pictures 20 12-19-2016 12:42 PM
Modify Harbor Freight Dolly? SilverGhost *General Road Glide Discussions/Pictures 27 04-18-2015 08:16 PM
Modify stock exhaust? Uncleford Do-IT-Yourself 13 04-12-2013 07:45 PM
Premier Liner Kit for Hard Saddlebags spider424 Classifieds Archive (3 months old+) 1 06-26-2011 03:47 PM
