2017 shock adjustment - Road Glide Forums
  • 1 Post By twowheeladdict
post #1 of 2 (permalink) Old 09-19-2017, 02:37 PM Thread Starter
Looking at the rear shock set up on my 2017 special i noticed that only the left shock adjusts. There is nothing connected from left to right shock. Furthermore, the right shock is upside down and has at least a 1/2 inch more travel than the left. I would think that both sides of the swing arm would need to be identical for rigidity.
Neutant is offline
post #2 of 2 (permalink) Old 09-19-2017, 02:55 PM
twowheeladdict's Avatar
this is becoming common in the motorcycle industry. One shock is set to a specific preload and spring rate, and the other shock has the adjustment for preload. They work as a unit because the swingarm is designed not to flex.. Some bikes have just one shock on one side of the swingarm. Some bikes have a single sided swingarm.
In Harley‘s case it is part simplicity and part budgetary. Most people wouldn't want to adjust preload on both shocks. They could have made rebound adjustment on the other.
They do the same with front forks where one side handles damping and one side handles preload.
JayKS likes this.
twowheeladdict is offline
2017 RGS handlebar adjustment? thereal142 Controls & Handlebars 8 03-24-2018 09:19 AM
Advice on shock adjustment with HD premiums Road dawg Suspensions 5 08-27-2015 08:58 PM
Hd Premium Shock adjustment ChromeYellow67 *General Road Glide Discussions/Pictures 8 01-16-2015 02:57 PM
Progressive Shock Adjustment help Easyryder01 Suspensions 10 08-04-2013 08:39 PM
Looking for a cheap spanner wrench for JRi shock adjustment jimmyray11349 *General Road Glide Discussions/Pictures 1 04-20-2013 10:05 AM
