air shock help - Road Glide Forums
post #1 of 7 (permalink) Old 10-19-2017, 09:00 AM Thread Starter
Slimboybinz's Avatar
air shock help
Can anyone tell me where I can get the doohickie that has the Schrader valve and the two push in connectors for the air shock system?
I just picked up a set of air shocks from a wrecked RGU that had only 1200Km on cost me about $75, but there was no tubing or this connector to pressure the shocks.
If they dont work, I havent really lost much.
Regards
SLIM
Slimboybinz is offline
post #2 of 7 (permalink) Old 10-19-2017, 09:58 AM
wevsspot's Avatar
Regards
SLIM
See my attachment and let me know if these are the parts you're referring to. I'm not sure where you'll find them in your locale but I can get you the OEM part numbers.
wevsspot is offline
post #3 of 7 (permalink) Old 10-19-2017, 01:08 PM Thread Starter
That is exactly what I need.
Thanks so much for your help so far.
I hope that I can find one used as the part from Harley will probably cost a fortune.
I think that these airshock parts are made by FESTO, but this one is probable a special for Harley.
RGDS
post #4 of 7 (permalink) Old 10-19-2017, 03:11 PM
wevsspot's Avatar
RGDS
Slim, with a little ingenuity, you could buy any air shock line kit and retrofit it to work just fine on your air shocks. There isn't any black magic. Save for convenience, you could just buy two schrader valves and retrofit them directly to the shock bodies. You'd have to fill each one individually, but less failure points than the cross-over tubing. Just a couple thoughts if you decide not to go the OEM route.
Unless the shocks have changed drastically all you'd need to convert to an individual valve for each shock is;
2- 1/8" NPT adapters
2- schrader valves
Any local shops that sell air compressors, compressor parts or pneumatic tools could probably set you up with everything you need if you take that picture to them. Wouldn't surprise me if a seasoned hand at your local hardware store couldn't do the same.
wevsspot is offline
post #5 of 7 (permalink) Old 12-08-2017, 03:18 AM Thread Starter
Thanks all for your input.
I found a source of the Schrader valves at an agricultural machinery shop of all places.
Just over a dollar each and with some PTFE tape they fit one per shock perfect.
No real trouble to se two shocks and they dont loose any air so far.
|Regards
SLIM
post #6 of 7 (permalink) Old 12-24-2017, 04:03 AM Thread Starter
update
|Regards
SLIM
Merry Christmas all in this great forum.
Just an update on my shocks - once I got the pressures right they are 100% better than the standard "premium".
It has been almost four weeks now and the pressure has been maintained exactly as set.
Best Wishes.
SLIM
post #7 of 7 (permalink) Old 12-24-2017, 11:40 AM
murray5p's Avatar
You can go to a heavy truck shop like Peterbuilt or Kenworth ,they have all you will need for your air systems, and I believe the tubing is 5/32 , they have all the brass fittings and push connectors as well , they use them on there shifters etc.
murray5p is offline
Rear Shock Air Line Help breeze *General Road Glide Discussions/Pictures 8 09-09-2013 03:37 PM
Air shock valve relocation boomerman *General Road Glide Discussions/Pictures 1 08-14-2011 05:21 PM
Stock Air Shock Lines Martin Suspensions 2 06-06-2011 01:32 PM
Arnott Air ride black 12" shock kit angelfrdad Classifieds Archive (3 months old+) 0 09-21-2010 11:56 PM
Help with correct Rear Shock air pressure for two up riding? zuppy51 *General Road Glide Discussions/Pictures 1 10-26-2009 10:08 PM
