Triple tree torque - Road Glide Forums
post #1 of 3 (permalink) Old 12-03-2017, 06:26 PM Thread Starter
Triple tree torque
I just finished my black front end swap on my 16 RGS. I followed the torque specs in the manual and it states to tighten the upper and lower pinch bolts to 14 pounds. For some reason to me that seems like it barely tight. Could someone confirm that this is correct.
THank you
mgrasso211 is offline
post #2 of 3 (permalink) Old 12-03-2017, 08:04 PM
BobRG15's Avatar
Correct 2015 manual calls for 14-18 foot lbs
Mako Fade Shark added Tour Pak with pass backrest-drivers backrest-pass floorboards-saddle bag guards
BobRG15 is offline
post #3 of 3 (permalink) Old 12-04-2017, 04:32 PM
9over's Avatar
upper steering stem ( the BIG nut) 16FT lbs. the pinch bolt (allen socket) 22 ft lbs. Please put lock tight on this it has a tendency to back out.
9over is offline
Rake Triple tree lek_vtwin Road Glide Builds-Document your builds HERE --NEW 21 07-01-2012 03:37 PM
triple tree clamp for apes? dirtracer27x Controls & Handlebars 7 02-29-2012 03:49 PM
Tri Glide Triple Tree pennstater *General Road Glide Discussions/Pictures 9 03-14-2011 08:42 PM
Possible loose triple tree bearings on 09 RG j schleifer Troubleshooting for Road Glides 3 01-28-2011 07:46 AM
Possible loose triple tree bearings j schleifer Troubleshooting for Road Glides 1 01-26-2011 05:58 PM
