Help - Road Glide Forums
 8Likes
post #1 of 14 (permalink) Old 04-16-2018, 07:25 PM Thread Starter
sfcusaret2004's Avatar
Help
not sure where to post this but initially posted it in the DIY forum. IOf this is where it belongs, I'll appreciate it if the moderators can let me know and I'll take it down on the other forum.
Took the forks off to replace the stock suspension on my 2013 Road Glide Ultra,with legends AXEO cartridges. While trying to get the 6mm bolt out of the bottom of the left fork lower slider, I just might have stripped head! Anybody encountered this before. What did you use to get the bolt out? Do you think a heat gun would make it easier to break the torque on the other one before I strip it too? Any ideas considered!
sfcusaret2004 is offline
post #2 of 14 (permalink) Old 04-16-2018, 07:31 PM
ChromeSpark's Avatar
I'm not sure by your post what 'type' of bolt head you're dealing with. Can you advise?
"It's a motorcycle, its not supposed to be comfortable, quiet or safe. The wind noise is supposed to hurt your ears, the seat should be hard and riding it should make you s**t your pants every now and then."
ChromeSpark is online now
post #3 of 14 (permalink) Old 04-16-2018, 08:51 PM
Bruckus's Avatar
I think your right it is a 6mm internal wrenching plug. Hopefully its your allen wrench thats messed up. You have to have a long allen preferably on a socket so you can get pressure pushing and twisting. A little heat will help if the plug had lock tite applied. Maybe try to soak in Kroil or similar. If the plug is truly stripped I would guess it would have to be drilled and extracted. Hopefully it's your allen wrench.
2013 Roadglide Custom - Candy Orange
Drago's Dragula True Duals, Thundermax Tuner
Daymaker LED Headlights, Supershox
Bruckus is offline
post #4 of 14 (permalink) Old 04-17-2018, 09:58 AM Thread Starter
The part I'm talking about is Item#23, PN#45405-75A, SCREW, w/ washer (2), Found on the Fork, Front, Left and right, (Fairing Model) page in the owners section of the HD website,https://serviceinfo.harley-davidson....184&groupId=14
It may be that the hex driver I used (ball head) which was the only one I could find locally, was deficient. I ordered 3 more drivers from Grainger this morning for pick up tomorrow, along with some 3-in-1 penetrating oil, which I will use along with a heat gun tomorrow to try and get this bugger out. Wish me luck!
post #5 of 14 (permalink) Old 04-17-2018, 10:06 AM
Little Wing's Avatar
impact driver
Singlebeam and ChromeSpark like this.
Little Wing is offline
post #6 of 14 (permalink) Old 04-17-2018, 10:31 AM
Lord Vader's Avatar
Those ball drivers suck. Not enough contact with the bolt. I only use those if I need to angle it. Get a good socket and put it on a impact gun. That should torque it right off if you didn't strip the bolt.
JOIN THE DARK SIDE
Lord Vader is offline
post #7 of 14 (permalink) Old 04-17-2018, 10:42 AM
Morningwood's Avatar
Don't think I can help, but as said use an impact on the other one. I put axeos in also, the impact popped them right out. Heat will definitely not hurt any thing. If it is stripped, try to get a square or torx in there, heat it good. And try an impact, good luck.
ChromeSpark likes this.
Morningwood is offline
post #8 of 14 (permalink) Old 04-17-2018, 11:02 AM
Heat gun might not be enough, try a propane torch, heat it until just before the oil ignites
post #9 of 14 (permalink) Old 04-17-2018, 06:42 PM Thread Starter
Thanks guys, I have to wait until Grainger opens in the morning to pick up my new impact 6mm driver to see if I can get this damn thing out. Will try 3-n-1 penetrating oil and a heat gun on max, if that doesn't work I'll probably end up drilling it out. Will let you know how it goes.
post #10 of 14 (permalink) Old 04-18-2018, 05:15 AM
bikerglasses's Avatar
I used a 25" breaker bar and had no issue at all. I also used a 6mm 1/2" drive impact socket. Both pieces I bought from harbor freight. I honestly dreaded the 6mm bolt from all the posts I read on how it was going to be a problem, but with the breaker bar I had no issue at all. Hope it works out for you.
6mm:
https://www.harborfreight.com/8-pc-1...set-67895.html
25" breaker bar:
https://www.harborfreight.com/12-in-...bar-62729.html
Ian -- Tucson, Arizona
- MGS True Duals, Ness Big Sucker, 12' Twin Peaks, -1" Monotubes
bikerglasses is offline
Boom stuff HELP HELP FLTRXXX Audio 1 04-14-2016 07:11 PM
Help.help!! Handle bar install CPY84 Controls & Handlebars 2 03-04-2013 07:31 PM
