Lowering the bike - Road Glide Forums
 3Likes
post #1 of 16 (permalink) Old 05-05-2018, 05:47 AM Thread Starter
Daveo1964's Avatar
Lowering the bike
Thinking of lowering my RGS17 should I use a lowering kit or put new shocks on?
Want to lower it about 1" in the back.
Daveo1964 is offline
post #2 of 16 (permalink) Old 05-05-2018, 06:31 AM
twowheeladdict's Avatar
Can you actually find 11" shocks for our bikes that have any travel in them? The 12" shocks barely have any travel. I have experienced the roads in MA and definitely would not want to loose any shock travel.
Maybe try and find tires with a smaller diameter to fit on the rear rim?
Keep in mind that lowering just the rear changes the geometry of the bike and will adversely affect cornering clearance and turn in.
twowheeladdict is offline
post #3 of 16 (permalink) Old 05-05-2018, 07:15 AM
BH#103's Avatar
Look into air ride for the back.
"SLIVER"
BH#103 is online now
post #4 of 16 (permalink) Old 05-05-2018, 08:14 AM
JacktheBagger's Avatar
I had LA Choppers 1" lowering blocks on mine .. Did fine but wasn't for me ..
Sinjin likes this.
2011 Ultra
JacktheBagger is online now
post #5 of 16 (permalink) Old 05-05-2018, 05:30 PM
Tourhog's Avatar
Can’t speak for a special but I just put Covington Customs lowering blocks on my Ultra and the work fine.
2013 RGU BBP
Tourhog is offline
post #6 of 16 (permalink) Old 06-28-2018, 01:02 PM
How do you lower the front of the bike. I like the look of the faring close to the fender. Does that make a horrible ride?
sadeeky is offline
post #7 of 16 (permalink) Old 06-28-2018, 01:13 PM
Morningwood's Avatar
I know legend axeo cartridges have a 1" lower version. I bought standard height and they still lowered the bike1/2 to 3/4.
Morningwood is offline
post #8 of 16 (permalink) Old 06-28-2018, 01:21 PM
Sport bike riders slide the forks up in the triple trees and put a larger diameter tire on the rear to make the bike more nimble in the twisties while sacrificing stability on the interstate.
If you lower both the front and the back the same amount you keep the geometry the same, but affect cornering clearance. I recall someone putting shorter fairing brackets on which lowered the fairing closer to the fender and changed the line and look down the side of the bike.
post #9 of 16 (permalink) Old 06-28-2018, 07:47 PM
MightyWhitey's Avatar
There are different ways to accomplish it.
I chose:
Progressive monotube -2”
Ohlins 774 12” with 1” lowering blocks.
I don’t consider it a horrible ride. I enjoy the planted feeling of a stiffer suspension. The Front was harsh with pot holes and sharp bumps with the stock height suspension so......
MightyWhitey is offline
post #10 of 16 (permalink) Old 06-28-2018, 08:15 PM
I chose:
I like that front wheel. What size is that? I'm new the the Bagger world and I'm looking to get a big front rim. What size can I go up to with out modifications?
Sent from my SM-G935P using Tapatalk
sadeeky is offline
Opinions on lowering my bike! I ALREADY DID THE DIY MONROE SET UP! So not an option! bigshaqa Suspensions 5 03-06-2016 10:19 AM
hd lowering Cartridge Fork Kit or progressive lowering kit IranAround Suspensions 11 03-21-2015 12:09 PM
lowering kits???? 3FEETUNDER Aftermarket Accessories 28 01-07-2011 07:00 PM
2010 rear lowering kit jjyoung *General Road Glide Discussions/Pictures 9 07-03-2010 08:12 AM
Lowering the Glide joke *General Road Glide Discussions/Pictures 17 02-07-2010 02:35 PM
