‘15 RG Ohlins upgrade. - Road Glide Forums
post #1 of 6 (permalink) Old 05-24-2018, 09:59 PM Thread Starter
UT_Larry's Avatar
Just upgraded to FC102 & BL 771.
When with the black line 771 for the rear. I wanted to stay at 12 height & I knew I would not be making adjustments.
So far I love them, knew in less than one block, about 5 miles so far. Biggest surprises so far, better acceleration & braking performance (non abs). Main reason for upgrade I was sick & tired of the inconvenience & inconsistency of the stock air preload. Since I was going to upgrade the rear I figured I would do front also. Looking forward to longer rides this weekend. Worth every penny.
UT_Larry is offline
post #2 of 6 (permalink) Old 05-24-2018, 10:16 PM
I went with ohlins from Howard. Best money spent on 13 rgu,WR.
whiskeyrider is offline
post #3 of 6 (permalink) Old 05-28-2018, 06:21 PM
tj316's Avatar
Ohlins are the best, when you start their you are done. Congrats
tj316 is offline
post #4 of 6 (permalink) Old 05-28-2018, 06:55 PM Thread Starter
UT_Larry's Avatar
You are right. I do believe in doing it right the first time even if it costs more. Just got back 100+ mile canyon ride. Three canyons different speeds and complexities. Öhlins what a great improvement over stock.
UT_Larry is offline
post #5 of 6 (permalink) Old 05-28-2018, 07:20 PM
Gmstump41's Avatar
Congrats on the Ohlins! I've put about a thousand mile on mine since I installed front and rear. They are awesome!
2013 RGU Ember Red Sun glow /seat mod, Madstad 13", heritage bars.
2007 Street Bob bought new, traded with 62000 miles. USMC 84-90
Gmstump41 is offline
post #6 of 6 (permalink) Old 06-18-2018, 02:06 AM Thread Starter
UT_Larry's Avatar
UPDATE Just finished my first ride in the rain since the upgrade. Braking is extremely improved due to less nose dive & better weight distribution. Could apply a lot more braking force without loosing rear end traction. My only regret is that I waited so long to upgrade to Ohlins.
UT_Larry is offline
Klock Werks Pro-Flare 15" Clear for 15+ RG tsmartt Parts for Sale 0 08-12-2016 01:14 PM
Single din upgrade 15 RG L.Cameron103 Aftermarket Accessories 1 07-16-2016 11:35 AM
15/16 RG radio upgrade ??? 93-331-29psi Audio 3 09-11-2015 10:00 AM
Ohlins HD 357 vs Ohlins HD 022 mach65 Suspensions 8 09-08-2015 10:54 PM
Stock parts from 15 RG build and misc pre-15 parts redeye93 Parts for Sale 0 02-15-2015 04:35 PM
