rear shock upgrade - Road Glide Forums
 5Likes
post #1 of 19 (permalink) Old 07-30-2018, 08:01 PM Thread Starter
blj9511's Avatar
rear shock upgrade
I have a '13 Roadglide Custom and looking to replace the POS factory air shocks. I have located some of the 12" Premium hand adjustable shocks off of a '16 CVO.
Would that be a good inexpensive upgrade? Thanks.
Road dawg likes this.
2013 Road Glide Custom FLTRX Vivid Black
Fullsac "C" X-pipe, Fullsac "recore kit" slip ons, Ness "Big Sucker" AC, PowerVision tuned by FuelMoto
blj9511 is offline
post #2 of 19 (permalink) Old 07-30-2018, 08:27 PM
skratch's Avatar
sure, it would be a slight upgrade. depends on the price if it's worth it or not. less than a couple hundred bucks, i would go for it. much more than that and you start getting into the range of 'you can get much better for not much more money'.
me personally, i had the 12'' premium adjustables. they were okay, but i found them to be kind of harsh on 'sharp' bumps, like small ridges in the road, etc. finally broke down and got a set of ohlins. more travel, and actually sat lower after adjusting the sag. rides much better....
widerider03 likes this.
skratch is offline
post #3 of 19 (permalink) Old 07-30-2018, 08:35 PM
gldlver's Avatar
if your looking to cheap out may as well stay with what you got. With that I spent the $800 on Supershox and man I tell you what that was probably the best investment I made, just got them dialed in after about 1500 miles of tuning, amazing what just a 1/8 turn can do
this is all my Opinion of course
Jwams likes this.
gldlver is offline
post #4 of 19 (permalink) Old 07-30-2018, 08:57 PM
mastergunnera8's Avatar
I have the 13" CVO ones, they are a big improvement over stock. BUT, if you can help it, get the 13"...12s are harsh
Obviously they aint Ohlins...If ya got it ($$$), go for it!!
mastergunnera8 is offline
post #5 of 19 (permalink) Old 07-31-2018, 12:07 PM
texasnurse's Avatar
Im a bit of a hard @$$ but I like my 12 Low shocks on my 18 FLTRXS; they run best if set to your weight geared out plus 40lbs
texasnurse is offline
post #6 of 19 (permalink) Old 07-31-2018, 01:17 PM
jcarruth's Avatar
The stock 12" Showa setup on '17+ RGS works just "ok" IF you have the preload set just right. However, the design absolutely sucks. Basically, the left shock and spring do the vast majority of the work. Check this out:
https://www.youtube.com/watch?v=iKZ1BQgXPuc
Before you spend a bunch of money on chrome do-dads, stage 1, and stereo upgrades, invest in something that really matters, your suspension. I went with 13" Ohlins HD 159s. It transformed the bike.
2017 HD Road Glide Special
jcarruth is offline
post #7 of 19 (permalink) Old 07-31-2018, 01:24 PM
Yes. I'm running the 12's and in my humble opinion, they are better than the factory air shocks...not as harsh. I run mine on the soft side, still experimenting between 10 and 15 turns. Picked up a like-new set for $150. Would prefer a better set of Ohlins / Supershox / etc., but not enough coin right now to upgrade. But a quality pair of rear shocks is definitely on my list. Already running Monotubes up front...another reasonably priced upgrade. Bike is a '13
Bodeen is offline
post #8 of 19 (permalink) Old 07-31-2018, 01:35 PM
texasnurse's Avatar
rear shock upgrade
One side controls dampening the other side rebound.
Coming from a sport bike the factory shocks are a dream plus I weigh about 270 dressed
post #9 of 19 (permalink) Old 07-31-2018, 02:21 PM
Morningwood's Avatar
Awesome video, it really shows what you get on $26,000 plus investment.
Morningwood is offline
post #10 of 19 (permalink) Old 08-01-2018, 01:04 PM
jcarruth's Avatar
I don't follow what you are trying to say here.
There is such a thing as rebound dampening and compression dampening - which side are you saying does what?
There is no dampening adjustment on the OEM shocks.
The right shock is like a small spring on a trombone. It doesn't appear to do anything, per the video.
The left side has preload adjustment. I am assuming there is set rebound dampening in that shock. Don't know for sure.
Generally speaking, sport bike shocks are way more adjustable than what we see on the new RGs.
jcarruth is offline
Upgrade my Legends air ride to a quality shock Bigfoots03hd Suspensions 9 08-08-2017 05:34 PM
Rear Shock Leak Down MakeARunMike Suspensions 10 07-22-2011 09:54 AM
04 rear shock psi question. schnid72 *General Road Glide Discussions/Pictures 6 02-27-2011 10:26 AM
Rear Shock Swap pte359 Aftermarket Accessories 19 07-23-2010 09:13 PM
Help with correct Rear Shock air pressure for two up riding? zuppy51 *General Road Glide Discussions/Pictures 1 10-26-2009 10:08 PM
