Need bike lower - Road Glide Forums
post #1 of 8 (permalink) Old 08-09-2018, 07:03 AM Thread Starter
Dixieboy05's Avatar
Need bike lower
I have a 2018 RGS. I want to lower the bike. I feel like when coming to a stop it will help me be more stable putting my feet down. I have no clue about where to start with this. Is the factory suspension adjustable for height? Do I install front and back components? TIA
Dixieboy05 is offline
post #2 of 8 (permalink) Old 08-09-2018, 10:16 AM
Diese's Avatar
Lower seat is another option... Iím 5í7Ē and put a Mustang lower seat and Iím very happy. If you lower the bike you lost lean angle. JMO
"Leave the gun take the cannoli" Clemenza
Diese is offline
post #3 of 8 (permalink) Old 08-09-2018, 11:49 AM
rydin2's Avatar
^^^^^ This ^^^^ You can also modify your stock seat by narrowing the the tank end to allow your legs to drop straighter toward the ground. If you have an automotive upholstery shop or custom seat builder in your area, check them out. I have done this with most of my bikes. I'm also 5"7''. The RGS suspension is already pretty low. Lowering it further IMO would be a last resort.
rydin2 is offline
post #4 of 8 (permalink) Old 08-09-2018, 12:04 PM
guerra's Avatar
I will never lower a bike again. As already said above I would modify the seat. I am 5’5” and have stock suspension on my 17. I did however send my stock seat to Mean City Cycles for the super narrow mod. I also run a Drag Specialties seat thats a bit lower than stock.
guerra is offline
post #5 of 8 (permalink) Old 08-09-2018, 01:08 PM
twowheeladdict's Avatar
Make sure you roll up off your butt when you come to a stop. That gives you the longest reach to the ground. I have the low tour solo with pillion mounted on my Special and with my 32" inseam I can put my legs out in a wide triangle when I roll up off the seat.
twowheeladdict is offline
post #6 of 8 (permalink) Old 08-09-2018, 01:13 PM
Willy_B's Avatar
Need bike lower
Iíve run every bike Iíve owned lowered and with a lowered seat. My 12 and 17 glides were both lowered 2Ē in the front with progressive monotubes and the rear of my 12 i ran 1Ē lowering Blocks until i eventually switched to air ride. Iím getting ready to do air on my 17 otherwise Iíd run Blocks as well. The stock seat and suspension set up sucks. I felt like i was sitting on phone books on top of a dirt bike i sat so high.
Willy_B is offline
post #7 of 8 (permalink) Old 08-10-2018, 08:23 AM Thread Starter
Dixieboy05's Avatar
Willy b what brand air suspension are you looking into because I was really looking into that as well. I just worry being on a long ride and something going wrong with the air suspension then what?
post #8 of 8 (permalink) Old 08-10-2018, 10:11 AM
Willy_B's Avatar
Im going to use airfx shocks that i took off of my 12 before selling. Best air shocks Iíve ever used and Iíve tried almost every company out there. You pay for it though, the shocks are expensive as hell but well well worth it in my opinion. As far as something going wrong on a long ride itís a crap shoot. I try to keep my systems simple, meaning no air tanks or pressure switches and all that stuff. I keep a push to connect tee with a schrader valve on it in case of failure. I can throw the tee in any line on the bike and stop by any gas station to fill it up. Also keep extra air line in case needed.
Willy_B is offline
Short legs - need to be lower on the bike tbschlegel Seating: seats, backrests 0 08-18-2018 10:49 AM
Need to lower bike kwcommando Suspensions 22 01-12-2018 06:50 AM
If I lower the rear do I have to lower the front?? StrokerAce Suspensions 13 11-17-2013 01:32 PM
WTB Lower fairing top U clamps to fasten the lower fairings to the crash bar. hogger Wanted! (Buy or Trade) 12 05-20-2012 05:46 PM
Need ideas on lower fairings install SharkNose *General Road Glide Discussions/Pictures 6 01-10-2011 07:55 PM
