Acceptable leakdown rate? - Road Glide Forums
post #1 of 6 (permalink) Old 09-25-2018, 07:38 AM Thread Starter
2016 Roadglide with the stock Air Suspension...Is there an "acceptable" leakdown rate? Down about 5 psi or so, but it's been a while (2 months?) since I checked it. I'm not terribly worried, just wondering if there's any information out there. Also, are there any known failure points in the air ride system I should be looking at?
Vertol is offline
post #2 of 6 (permalink) Old 09-25-2018, 11:22 AM
Clutch1's Avatar
Mine would change with the weather. Had the stock ones for 60,000 miles. Put the supershox ones on and they made a world of difference in the ride and no more air. Sold the air pump lol.
04 Road Glide
Clutch1 is offline
post #3 of 6 (permalink) Old 09-25-2018, 12:07 PM
Lundbeno's Avatar
I've think the old air shocks are more comfortable than the new stock rear suspension.
I had an 07 and thought the same, should I check it, ok...leakage, going 2up, look at the chart, adjust - then re-adjust again. I went with Progressive's on the 07 and it was a huge upgrade.
I just did Ohlins on my 18 and it's like night and day.
To answer your question, I saw fluctuation between air temps, but no leakage to say I have a problem.
Lundbeno is offline
post #4 of 6 (permalink) Old 09-25-2018, 01:30 PM
ChromeSpark's Avatar
I had some larger than I thought acceptable and the warranty tech recut all the ends square and rechecked for leaks. They stated it happens some of the time. Now I'll lose about what you're rate is, but seems dependent on usage? maybe?
I've soaped the lines and found no leaks.
"It's a motorcycle, it´s not supposed to be comfortable, quiet or safe. The wind noise is supposed to hurt your ears, the seat should be hard and riding it should make you s**t your pants every now and then."
ChromeSpark is online now
post #5 of 6 (permalink) Old 09-25-2018, 01:34 PM
twowheeladdict's Avatar
My '16 was fixed under warranty and had no issues after that. I would continually adjust the air for different loads so never let it go long enough to say there was a slow change.
twowheeladdict is offline
post #6 of 6 (permalink) Old 09-25-2018, 01:39 PM
UT_Larry's Avatar
Had them on my 15 RG. Upgraded to Ohlins front & rear. Best money spent. Bike handles & performs like a completely different bike. Braking is greatly improved! For safety reasons alone I recommend getting rid of the stock air suspension. I was sick & tired of the inconsistent ride due to bleed down, that is why I upgraded. Only regret is I should have done it when I bought the bike in 15.
UT_Larry is offline
Oil consumption rate ? freedom1974 *General Road Glide Discussions/Pictures 19 09-21-2016 08:44 PM
Not extreme or even high rate ddm502001 *General Road Glide Discussions/Pictures 18 05-16-2014 07:46 AM
