Mixing different brands for upgrades - Road Glide Forums
 11Likes
post #1 of 13 (permalink) Old 10-16-2018, 08:41 PM Thread Starter
I have a 2015 RG Special. I just replaced my rear shocks with Legends Revo Coils. Love the difference, now I want to upgrade the front forks. Any recommendations on whether to stick with same brand or any reason I could not go with Ohlins? I want a balanced ride so not wanting to mix up something that does not work together.
Comments?
Waistdeep is offline
post #2 of 13 (permalink) Old 10-16-2018, 10:48 PM
MatteGlide15's Avatar
I went with the Legends Axeo front end kit for my 2015 RGS. 100% better improvement from stock setup. I’m running 13” Pro-Action shocks in the rear
Waistdeep likes this.
#SharkNation
MatteGlide15 is offline
post #3 of 13 (permalink) Old 10-17-2018, 09:34 AM
08Zinc's Avatar
I am running Progressives on the front and Super Shox on the rear. No issues at all with my mixing of manufacturers.
Blessings, Zinc -
08Zinc is offline
post #4 of 13 (permalink) Old 10-17-2018, 11:04 AM
Morningwood's Avatar
I did Legend axeo in the front and Super shox in the rear, 100% satisfied. I see no problem putting ohlins in the front.
Morningwood is offline
post #5 of 13 (permalink) Old 10-17-2018, 11:28 AM
BigBlockBobby's Avatar
Just my opinion, if you are happy with the Legend in the rear then do the same in the front.
It's not like you will hurt anything by mixing brands but why not have a set tuned to work together. Legend will tell you where you need to have them setup for by weight and riding style instead of making adjustments to figure it out on a mix matched set.
VikingRider and Waistdeep like this.
BigBlockBobby is offline
post #6 of 13 (permalink) Old 10-17-2018, 12:06 PM
Oldbie's Avatar
A slight hijack; does anyone make an externally adjustable system for the front suspension?
It is difficult to free fools from the chains they revere.
Oldbie is offline
post #7 of 13 (permalink) Old 10-17-2018, 08:00 PM
FastHarley's Avatar
adjustable
Yes, I do, a fully adjustable 25mm with R&T internals & a 30mm R&T, ask around and you will see many people with them. I have been doing the 30mm fully adjustable somewhere around 2008 or so but can not remember back that far. The same 30mm are just now available in the Ohlins inverted forks used at the track on race bikes.
tj316 and Oldbie like this.
FastHarley is offline
post #8 of 13 (permalink) Old 10-18-2018, 12:33 PM
Oldbie's Avatar
Do the forks retain an overall stock look?
Oldbie is offline
post #9 of 13 (permalink) Old 10-18-2018, 01:42 PM
FastHarley's Avatar
ask around
Unless you remove the nacelle to look at the fork caps. They go into stock 49 mm forks. No one can tell except for you, the rider.
Oldbie likes this.
post #10 of 13 (permalink) Old 10-18-2018, 05:19 PM
Oldbie's Avatar
Is any machine work required or is it "drop in"?
Oldbie is offline
mixing speakers BubbaBeef Audio 11 02-05-2018 12:26 PM
Mixing and matching performance parts Road dawg Tech Area 10 03-27-2016 10:00 AM
Mixing Speakers sometimer Audio 2 02-22-2016 01:10 PM
Mixing impedance dmiller Audio 2 03-30-2015 10:19 AM
Harley mixing standard and metric too cyclotron *General Road Glide Discussions/Pictures 10 02-27-2011 03:44 PM
