Front suspension - Road Glide Forums
 10Likes
post #1 of 23 (permalink) Old 01-02-2019, 05:04 PM Thread Starter
Clutch1's Avatar
Front suspension
So I知 tackling the front end. I have to rebuild the front forks as they have not been done since new. I figure I値l get all new internal pieces for it. Any suggestions for aftermarket companies to look at. I知 sure I値l get the seals from HD but other then that I壇 like to look for something a little less rough.
I have supershox on the rear at this time.
Thanks
04 Road Glide
Clutch1 is offline
post #2 of 23 (permalink) Old 01-02-2019, 05:35 PM
08Zinc's Avatar
I have Super Shox on the rear as well and the Progressive monotubes work well for me on the front end. Had them on for over a year and been extremely pleased with the difference over stock.
Idahokid likes this.
Blessings, Zinc -
08Zinc is offline
post #3 of 23 (permalink) Old 01-02-2019, 05:36 PM Thread Starter
Clutch1's Avatar
Awesome. I値l look into them. Thanks.
04 Road Glide
Clutch1 is offline
post #4 of 23 (permalink) Old 01-02-2019, 05:38 PM
BH#103's Avatar
Check out the kits from James Gaskets. I used their kit years back when I did my 2012 front suspension. Anything in the kit that had a part # stamped on it was the same part # stamped on the OEM Harley parts. Good luck!
"SLIVER"
BH#103 is offline
post #5 of 23 (permalink) Old 01-04-2019, 09:15 AM
Check out the legends axeo cartridges! or ohlins nix22
RedBlack likes this.
Toplesspolak5 is offline
post #6 of 23 (permalink) Old 01-04-2019, 09:22 AM
I'm also running the Legend AXO fronts on my 2018 RGS, but they are a bit pricey.
2018 Road Glide Special Wicked Red SVT BoneShaker Exhaust, RCX Tormentor Headers, FP3, Vance & Hines VO2 Naked Air Intake, AIMS Light Force Slave Cylinder, Legends REVO-A Shocks
aviscomi is offline
post #7 of 23 (permalink) Old 01-04-2019, 09:46 AM
RGKen's Avatar
If you don't want to go the gas cartridge route due to cost you can buy fork spring kits from Progressive pretty cheap that are better than the stock one. The route I would go on your '04 is the kit from Race Tech that have the gold valve cartridge emulators. You can customize it for your weight and desired feel. I installed this kit in my 2010 FLTRX and it rode and handled better than the Progressive monotubes I put in my 2012.
Harley-Davidson
Idahokid and Little Wing like this.
2018 FLTRXS
RGKen is offline
post #8 of 23 (permalink) Old 01-04-2019, 11:21 AM
SteadyEddie's Avatar
@Smarty - Ohlins Fronts......Done and Done
Had them on my '15 Beast and they were/are SPECTACULAR
RGKen and dreeves like this.
SteadyEddie is online now
post #9 of 23 (permalink) Old 01-04-2019, 12:21 PM
On my RGU I took a spring kit by progressive, a low cost solution that came out to be effective for my needs.
More info here: https://www.roadglide.org/50-suspens...%9D16-rgu.html
Beaver is offline
post #10 of 23 (permalink) Old 01-04-2019, 12:22 PM
springerider's Avatar
Ohlins on the rear...just pulled the trigger on cartridges for the front. I don't have a lot of money but there's a reason I don't buy half-assed tools...
RFG7680 likes this.
鄭ny society that would give up a little liberty to gain a little security will deserve neither and lose both. Benjamin Franklin
2018 FLTRXS (newest money pit)
2004 FXSTS 104 HP/112 TQ
springerider is offline
Front suspension 'rough' mpears53 Suspensions 13 08-01-2017 06:37 AM
New Progressive suspension front & rear. TRUBlue Suspensions 16 04-18-2013 09:29 PM
Evo front air suspension thedude Suspensions 4 12-31-2012 02:55 PM
Front Suspension Not_A_CVO Suspensions 7 08-15-2011 03:19 PM
front suspension jscal Troubleshooting for Road Glides 1 06-21-2011 07:33 PM
