Front Suspension - Road Glide Forums
 11Likes
post #1 of 12 (permalink) Old 01-10-2019, 10:23 AM Thread Starter
NickyNuts's Avatar
Front Suspension
Front and rear suspension changes are now on the to do list for the 19 riding season. I have 1 question for those that have changed their own front suspension. Does the entire front fairing have to come off the bike to remove the fork tubes?
NickyNuts is offline
post #2 of 12 (permalink) Old 01-10-2019, 10:32 AM
No, none of it does.
Big_gary is online now
post #3 of 12 (permalink) Old 01-10-2019, 10:37 AM
calgaryglide's Avatar
No. The front fairing doesn't have to come off to change the front forks. You will have to remove the speedo and tach housing to access some of the fasteners, this is minor compared to removing the whole front fairing.
Wise investment would be the service manual for your year of Road Glide. Details of how to disassemble the front forks and any special tooling required to do so are listed in that service manual. HD special tools can be substituted with a little imagination and ingenuity.
Also, there are many youtube videos out there of folks that have done this same work, find a reputable one to follow and watch how they do it.
Regards,
Calgaryglide
Mike U, fitscott and ALMOONEY like this.
calgaryglide is online now
post #4 of 12 (permalink) Old 01-21-2019, 12:24 PM Thread Starter
NickyNuts's Avatar
Thanks for your replies, just what I was hoping would be the case. I want to do the front suspension myself since the 2 estimates I have gotten for the installation alone cost more than Progressives Monotubes and was only a little less than the cost of Legends. I do possess better than average mechanical ability and with the exception of a few specialty tools for the job, have all the tools I would need. In my younger days I was a drag racer (cars) doing all my own mods and complete engine rebuilds. I do have the service manual for my 17.
Mike U and Ohiobellboy like this.
post #5 of 12 (permalink) Old 01-21-2019, 04:53 PM
mwattpusher's Avatar
I just did my own swap over to the Legends Axeo and it was as a straight forward job. You’ll need a 12mm hex socket for the bottom of your lowers, then a 3/4” hex socket for the top cap of your upper tubes. When you go to install the completed forks follow your service manual for the fork torque sequence and install measurements. By the way, I’m happy with my new suspension.
ALMOONEY and crazy4ink like this.
mwattpusher is offline
post #6 of 12 (permalink) Old 01-21-2019, 06:54 PM
Like has been said, taking the forks out of a RG is a helluva lot easier and quicker than on a batwing style bike. Once you remove the speedo/tach cluster, you can get to the 3 bolts (per side) that will release the forks. You'll need a 1/4" allen for the pinch bolts, a 15/16" socket for the axle nut, a 6mm allen for the axle pinch bolt, a 12 point 10mm for the brake caliper bolts, a 1/4" allen for the 4 fender bolts, a T25 for the 2 screws on the speedo/tach housing, a 12mm long allen for thge damper bolts on the bottom of the fork legs and a 19mm allen for the fork cap.
Mike U likes this.
2018 FLTRXS Wicked Red
Harley Master Tech
crazy4ink is online now
post #7 of 12 (permalink) Old 01-21-2019, 08:13 PM
madmat's Avatar
Just a suggestion, if you start with the rear you may find you don't need to do the front.
The front on the newer bikes is not bad, the rears are rough.
Mike U and MightyWhitey like this.
18 RGS Bonneville Salt Pearl
madmat is offline
post #8 of 12 (permalink) Old 01-22-2019, 12:08 PM
Is there a big difference between the 41 MM (pre 2017) and the newer 49 MM tubes?
fitscott is offline
post #9 of 12 (permalink) Old 01-22-2019, 05:33 PM
madmat's Avatar
I can't tell what mm sizes the tubes are. I can tell you this, on my 12 RGC I put 13" super shox in the rear and progresive monotubes standard height in the front and they made a big difference.
On my 17 & 18 RGS the front suspension is as good if not a little better than my 12 was stock. I put the same super shocks on the rear of my 17 and that bike rode excellent. I will be putting the same super shocks on my 18' shortly and don't forsee any reason to change the front.
I don't think it matters what brand of shocks you put in the rear and there are many good brands listed in this forum. They will all be better than the stock rear and drastically improve your front.
Good luck!
Little Wing likes this.
madmat is offline
post #10 of 12 (permalink) Old 01-23-2019, 08:54 AM
Thank you - That helps
fitscott is offline
How to Find your Diagnostic Trouble Codes ironmark Troubleshooting for Road Glides 42 05-03-2019 06:43 AM
Front suspension ebrider *General Road Glide Discussions/Pictures 0 05-25-2018 09:04 PM
2016 Road Glide Front Suspension Woes Riderdave Suspensions 32 05-06-2018 03:37 PM
Visit Arnott Motorcycle Air Suspension Products at 75th Annual Sturgis® Rally ArnottInc Aftermarket Accessories 0 07-29-2015 12:52 PM
front suspension jscal Troubleshooting for Road Glides 1 06-21-2011 07:33 PM
