Rear suspension - Road Glide Forums
 11Likes
post #1 of 16 (permalink) Old 01-12-2019, 09:54 PM Thread Starter
Rear suspension
Is it true the right rear shock does not get adjusted because it does nothing anyway?
Ksheehan330 is offline
post #2 of 16 (permalink) Old 01-12-2019, 10:04 PM
Woodman's Avatar
What year?
If you are talking about the later models with the adjustable shock on the left ,YES
Woodman is offline
post #3 of 16 (permalink) Old 01-12-2019, 10:18 PM
twowheeladdict's Avatar
It does do something. It has a spring. It helps hold the sprung weight of the bike. It just doesn't help with adding more preload.
twowheeladdict is offline
post #4 of 16 (permalink) Old 01-13-2019, 08:03 AM
RoadGlide18's Avatar
From what I’ve read, due to the rigidity of the rear swing arm they only need to make one adjustable. The same principle of a mono shock. Adjusting the one effectively increases the spring preloaded but like most would think there is an unbalanced effect but has no issue do to the design of the suspension as a whole.
cavedweller likes this.
RoadGlide18 is offline
post #5 of 16 (permalink) Old 01-13-2019, 08:59 AM
madmat's Avatar
Maybe if they put preload on BOTH sides the rear suspension would not Suck as much as it does?
Ooops, did that sound bitter?
18 RGS Bonneville Salt Pearl
madmat is offline
post #6 of 16 (permalink) Old 01-13-2019, 09:30 AM
gldlver's Avatar
no you correct on the SUCK, just do like I and many others on here did, take off the OEM rear JUNK and Throw in the garbage, order Aftermarket and never have your Spine compressed again
gldlver is offline
post #7 of 16 (permalink) Old 01-13-2019, 09:48 AM
madmat's Avatar
TY I did, my super shox are going on their 3rd RG shortly!
madmat is offline
post #8 of 16 (permalink) Old 01-13-2019, 12:31 PM
Little Wing's Avatar
X2!
my L5 is still thanking me for the upgrade
madmat likes this.
Little Wing is offline
post #9 of 16 (permalink) Old 01-13-2019, 12:41 PM
adawson1911's Avatar
Though only one side is adjusted for pre-load, the other side still takes on weight for balance. It seems to me that one side would still be under greater stress, but I'm not an engineer. In my opinion, if you are running low weight and not pushing the limits of the bike you can get by with them. I personally have purchased a superior suspension, but I probably could have gotten by if I wanted to wait longer.
Regards,
A. Dawson
"The great home of the soul is the open road" -D.H. Lawrence
adawson1911 is offline
post #10 of 16 (permalink) Old 01-16-2019, 02:10 AM
knotts89's Avatar
[/quote]
TY I did, my super shox are going on their 3rd RG shortly![/QUOTE]
I'm thinking about ordering some super shox next month. Did you go with the 14 inch and lowering blocks?
Ride today, tomorrows not promised
knotts89 is offline
MY 17-18 Rear Adjustable Suspension ?s calgaryglide Suspensions 6 03-28-2018 04:14 PM
13" to 13.5" rear suspension anyone ? Freaky Suspensions 15 06-02-2016 10:36 PM
Stock RGS rear suspension concern Beancount Suspensions 3 02-17-2015 07:28 PM
Front and Rear Air Suspension Q-Hog Suspensions 15 09-26-2014 12:49 PM
Adjustable rear suspension! Not_A_CVO Aftermarket Accessories 25 07-25-2011 07:46 AM
