Whatís your preload number? - Road Glide Forums
 3Likes
  • 1 Post By twowheeladdict
  • 1 Post By Thermodyne
  • 1 Post By UT_Larry
post #1 of 7 (permalink) Old 03-17-2019, 09:10 PM Thread Starter
KansasFLTRU's Avatar
I have 10,000 miles on my 2017 RGU. I read the operatorís manual regarding the preload shock setting for my height, weight, and style of riding. 5í7Ē, 185, ride solo and love curves. Iím certainly no racer, but ride aggressively in the mountains on trips to Arkansas. I had the preload set to 8. This weekend, while riding some curves around a local lake, I decided to experiment, and cranked it to 15. Canít describe the difference, other than to say awesome. New bike. Just wondering if anyone has some feedback for the adjustment on the stock shock. I never plan to change away from stock.
Thereís a place that I travel, when I want to roam, and nobody knows it but me.
2017 Vivid Black Road Glide Ultra
KansasFLTRU is offline
post #2 of 7 (permalink) Old 03-18-2019, 05:51 AM
RGKen's Avatar
I no longer run those shocks so I can't chime in on the setting but I am curious as to how height affects preload of the shocks?
2018 FLTRXS
RGKen is offline
post #3 of 7 (permalink) Old 03-18-2019, 06:12 AM Thread Starter
I donít know that height affects the preload number in any way. Just trying to give an overall description of the rider and riding style, and see how that compares with the number others choose. I will say that moving up to 15 made the RGU easier to get on and off its center stand. I donít know if 15 is anywhere near ďnormalĒ for other riders who are running stock.
post #4 of 7 (permalink) Old 03-18-2019, 07:57 AM
I don't have much to contribute due to the fact that the OEM shocks never were suited for me. I only weigh 140 lbs "soaking wet" my setting was 0 and still the shocks wouldn't budge an 1/2 inch. This is my 4 HD with these shocks and each time I swap them out for either Ohlins or Legends, which allow for lighter springs and sag adjustment.
2018 Road Glide Special Wicked Red SVT BoneShaker Exhaust, RCX Tormentor Headers, FP3, Vance & Hines VO2 Naked Air Intake, AIMS Light Force Slave Cylinder, Legends REVO-A Shocks
aviscomi is offline
post #5 of 7 (permalink) Old 03-18-2019, 11:50 AM
twowheeladdict's Avatar
Preload should be set based on measurements made regarding full stroke of the shock, and sag when the rider and gear are on the bike. Usually the sag is set to 1/3 the stroke of the shock as a starting point.
Setting the preload to a harder setting to reduce sag will slightly change the steering geometry and allow the bike to turn in easier. It will also provide a little more lean angle. The negative will be shock stroke on rougher roads and the possibility of reducing traction if the rear of the bike rises to where it hits the end of the shock stroke and the momentum lifts the tire with it.
KansasFLTRU likes this.
twowheeladdict is offline
post #6 of 7 (permalink) Old 03-18-2019, 12:14 PM
Thermodyne's Avatar
I have mine set on 18. And thought it was a little soft still. Then I got on the other roadie that has 300lb/inch springs on it and realised that at 18 its real soft.
Thermodyne is offline
post #7 of 7 (permalink) Old 03-18-2019, 02:20 PM
UT_Larry's Avatar
I would not say never. I did and then before I knew it I was on Ohlins.
mtbutler likes this.
UT_Larry is offline
part number needed for 2016 CVO Road Glide console. canderso1970 *General Road Glide Discussions/Pictures 10 09-25-2016 10:07 AM
Hammock seat part number question FDXGUY Seating: seats, backrests 3 10-19-2014 09:05 PM
Chrome and Rubber Large Brake Pedal Pad-42478-95 Part Number 42478-95 longrides Sold 1 05-03-2013 03:41 AM
parts number silverado705 Equipment-RG 3 03-17-2011 09:22 PM
