Ohlins install this weekend - Road Glide Forums
 22Likes
post #1 of 40 (permalink) Old 05-03-2019, 09:55 AM Thread Starter
craigffb's Avatar
Got a set of HD 772s in the garage that I'm going to put on this weekend. The main reason I'm posting this before the install is I'm kind of skeptical that they are going to make as much difference as I always read about.
I don't hate the OE stuff on the bike as much as everyone else apparently does. Matter of fact I never really think much about it at all. I always figured the cats bitching about the suspension being so bad were just kind of soft...LOL
So once I get them on and set up I'll come back and post my thoughts.
I'm hoping to be as impressed as everyone else.
Big_gary and Ohiobellboy like this.
craigffb is online now
post #2 of 40 (permalink) Old 05-03-2019, 02:15 PM
MisterEd's Avatar
It you have a Rushmore model you will notice a big difference.
Are those the adjustable length? Make sure to set the sag. It will make a difference. Also, it will take a couple hundred miles for them to settle in.
FYI..if you like the rears you'll end up changing out the fronts too.
MisterEd is offline
post #3 of 40 (permalink) Old 05-03-2019, 03:10 PM
RGKen's Avatar
If you are not aware, eye to eye is a different length on each side by a small amount. When you lift the rear of the bike to install the shocks, install the top bolt of each shock first then lift the bike to where the left side eyelet is aligned perfectly with the bolt hole on the swing arm so that you could install the bolt by hand freely. Then break the locknut loose at the bottom of the right shock to adjust the length so that you may now insert that bolt by hand freely without having to move the position of the bike up or down. Then lock the locknut back into place. This will help ensure that you will get them same adjustment on both sides instead of one shock being compressed a little more than the other.
twowheeladdict and ALMOONEY like this.
2018 FLTRXS
RGKen is offline
post #4 of 40 (permalink) Old 05-03-2019, 04:26 PM
twowheeladdict's Avatar
Setting them up correctly is 90 percent of what you will "feel". If you bought them from Smarty follow his directions.
It is better to have a second person to help set the static sag correctly.
twowheeladdict is offline
post #5 of 40 (permalink) Old 05-03-2019, 05:33 PM Thread Starter
craigffb's Avatar
It's a 19.
I was, but thanks. I swapped a set of take off HD hand adjustable' s onto my 12 Street Glide
I did in fact get them from Smarty. I'll be calling him so he can walk me through it.
RGKen and twowheeladdict like this.
post #6 of 40 (permalink) Old 05-04-2019, 08:08 AM
Idahokid's Avatar
I bet you’re going to notice a nice difference.I was looking at those too.The stock hand adjustable shocks just rode to stiff.Its nice to have some bounce.
Don't believe everything you think.
Idahokid is offline
post #7 of 40 (permalink) Old 05-04-2019, 08:26 AM Thread Starter
craigffb's Avatar
That's what I'm hoping for.
post #8 of 40 (permalink) Old 05-04-2019, 04:28 PM Thread Starter
craigffb's Avatar
I'm guessing it's ok to run the eye all the way in to make the shock as short as possible right?
post #9 of 40 (permalink) Old 05-04-2019, 04:46 PM
Ohiobellboy's Avatar
Yup.
craigffb likes this.
A.K.A OBB
Ohiobellboy is offline
post #10 of 40 (permalink) Old 05-04-2019, 05:09 PM
RGKen's Avatar
Yes on the short side but then you will want to run the other side out a couple of threads to make it line up with that hole. The objective is to not have one shock more compressed even by a little.
2018 FLTRXS
RGKen is offline
Twin Power 34 Tooth Compensator Eliminator Install Hawkeye1 Engine Related 43 10-11-2019 07:56 AM
Monotube install on 2013. bikerglasses Suspensions 3 01-16-2018 08:21 AM
Daymaker Light Install - Install Problem - And Resolution Martin Lighting 22 06-06-2013 07:57 PM
HD Audio iPod Interface Install - 2011 RGC wachuko Do-IT-Yourself 26 12-31-2012 07:30 PM
UPDATE my 5x7 Hogtunes speaker and amp install SKULLZ Aftermarket Accessories 8 04-06-2010 09:45 PM
