Progressive Monotube - Road Glide Forums
post #1 of 13 (permalink) Old 02-17-2011, 10:55 PM Thread Starter
bigbrainbob's Avatar
Did a lot of research on the topic of front end suspension and was needing to come down 1" on the front end (challenged in the inseam department). I decided to go with the mono-tube by progressive which was done a couple of days ago and all I can say is that for all of the post I read in testimony for the mono-tube was actually right-on!!!!!
No dip in the front end when breaking, I did not feel a compromise in the riding for the 1" lowering and the most amazing feeling was almost like you were riding on a rail, it was so steady it was unbelievable and NO! I don't work for progressive suspension.
So for all of you out there setting on the fence trying to make up your mind to pull the trigger, go for it!!! yes they're a little costly but well worth it, while you're at it, go ahead and change out for chrome forks, seeing that you've got to take the old forks off anyway, and no! the fairing did not have to come off to install the new suspension, labor hours were about 3.5 or 4 if you know what your doing, my dealer did this job.
You won't regret it.
Who's that peeping through my window,"POW" nobody now
bigbrainbob is offline
post #2 of 13 (permalink) Old 02-28-2011, 12:04 AM
CustomGlide's Avatar
Send a message via AIM to CustomGlide
Thank you! In the process of doing this kit right now (2" drop). Glad to hear that it will be worth it. Waiting on the damn powdercoat guy
CustomGlide is offline
post #3 of 13 (permalink) Old 03-11-2011, 10:19 PM
Got it all back together finally. Cant report on ride brcause we still have about 30" of snow here, but it sure looks good 2" lower!
post #4 of 13 (permalink) Old 03-14-2011, 11:43 PM
JonnyU
Guest
Posts: n/a
I am really interested. Please let us know the results. Any other owners chime in.
post #5 of 13 (permalink) Old 03-20-2011, 12:35 AM
Rode about 40 miles through many potholes with the full 2" drop. It will not bottom out and the front feels way better than stock did so far. It feels like is the perfect stiffness and softness combined. Got the bike up to about 80 and it feels very stable. I did quite a few changes to the bike in addition to the suspension such as a 21" wheel up front, and the monotube seemed to compensate for the supposed harsh ride as a result of the wheel change. I would highly recommend this setup so far and will keep posted if my experience changes. Very Happy
post #6 of 13 (permalink) Old 03-21-2011, 09:02 PM
chriscalabro's Avatar
I would agree. I have done every upgrade known to man. This is one ranks among the best. Rides like it is on a rail. Best upgrade for the dollars spent.
chriscalabro is offline
post #7 of 13 (permalink) Old 04-21-2011, 07:18 PM
BLACKHAWK's Avatar
Did you replace the oil seal while you had it torn down.
B.R.N.Y.S
BLACKHAWK is offline
post #8 of 13 (permalink) Old 04-21-2011, 07:36 PM
yes, despite the fact that the progressive require very little oil I did replace the seals while they were out
post #9 of 13 (permalink) Old 04-21-2011, 08:01 PM
BLACKHAWK's Avatar
I understand you didn't the fairing off? WOW!! Can you give me a few tips on how to do that without removing the fairing? My shocks should be coming soon.
B.R.N.Y.S
post #10 of 13 (permalink) Old 04-21-2011, 08:41 PM
No I had the fairing off. It could be done without removing the fairing if you could gain access to the two nuts at the top of the forks. But it would be easier to remove the fairing.
Progressive Monotube Review ironmark Suspensions 39 12-27-2013 12:24 PM
Progressive monotube dissatisfaction !!!! THEMASTERDESTROYER Suspensions 34 09-26-2013 04:56 PM
Progressive monotube story BLACKHAWK Suspensions 1 11-07-2011 12:42 AM
progressive monotube cartridge system THEMASTERDESTROYER Suspensions 3 09-25-2011 09:57 PM
Progressive monotube on RGU jupiter Suspensions 11 09-08-2011 09:58 PM
