When to change fork oil? - Road Glide Forums
post #1 of 19 (permalink) Old 04-14-2011, 07:46 PM Thread Starter
So, my 09 has about 20,200 miles on it. My manual says to change fork oil at 50,000 miles. I've heard in the past that the fork oil interval was 20,000 miles. So, when do you guys change your fork oil? Are you still using the 20k figure or 50K or something in between. I'm gonna upgrade to the SE heavy oil which I heard helps prevent excessive front end brake dive. I'm not experiencing any problems right now so I'm thinking about leaving it alone for now.
2009 Road Glide
Black Pearl, ABS, Security, and Cruise
Stage 1 A/C, download, and SE Slipon's
S&S Flywheel-balanced and welded
Timken Bearings in the case
Progressive 412 12" shocks
2011 Seat.
jcanrun is offline
post #2 of 19 (permalink) Old 04-14-2011, 07:53 PM
brhodea's Avatar
follow the HD recomendations and just ride it.
brhodea is offline
post #3 of 19 (permalink) Old 04-14-2011, 08:10 PM
At 20.000 it's time
Frodoe is offline
post #4 of 19 (permalink) Old 04-14-2011, 08:16 PM
allofus81's Avatar
I would also recomend staying with HDs 50000 mile interval. EXCEPT I just changed out my front forks for some black ones. With 7500 miles on my bike I could not belive how BLACK my oil was! Really makes me wonder if it got filled with used 20/50 from the factory?
allofus81 is offline
post #5 of 19 (permalink) Old 04-15-2011, 07:04 PM
smitty901's Avatar
New bikes 50k Do seal bushing oil for get it for another 50K.
Heres what bushing and seals look like at 50K.
color of the oil is meaning less the bushing wear to prtevent damage to tubes that is how it works.
smitty901 is offline
post #6 of 19 (permalink) Old 04-15-2011, 07:14 PM
brhodea's Avatar
After 1000 miles diesel engine oil looks very black. Doesn't mean its time to change it.
brhodea is offline
post #7 of 19 (permalink) Old 04-15-2011, 07:45 PM
allofus81's Avatar
Ok you guys want to jump on the intelligence train and take a ride? Whats making the fork oil dirty? There shouldnt be any impuritys getting in the forks, diesel engine has many reasons for impuritys mainly heat and lots of bearings rings and other things contributing! A FORK? Come on im no idiot. I work on a farm with more diesel engines than alot of you have ever seen in a lifetime let alone worked on. I was just stating that with 7500 miles the fork oil was really really really black. I have a 2010 John Deere 9530 that can run a full 250 hours on an oil change and the oil is cleaner than the fork oil on my 2010 Road Glide with 7500 miles with roughly 100 hrs on it. Just some REAL WORLD information. What to you guys got?
post #8 of 19 (permalink) Old 04-15-2011, 08:03 PM
smitty901's Avatar
One depending on the oil they used it could be black when it went in.
Two look at the bushing above they are coated it is designed to slowly wear off. It does that so the bush wear out and not the tubes. The coating will discolor the oil .
If you have bad seals the oil would show signs of leaking and or water mix in.
Fork oil is just another issue Hd owners love to beat them self to death with.
On newer bikes unless you notice a leak ride it 50K then service it.
Unless for dome reason you need a slightly heavier oil in them.
post #9 of 19 (permalink) Old 04-15-2011, 08:18 PM
brhodea's Avatar
I'm not doubting the train anyone is riding or trying to hop on one. Merely stating that the color of the oil is not the basis for changing it. Lets not get too testy. I used to run a maintenance out fit with 20 employees and 25 pieces of equipment 75% of which were deisel. I now work for an oil refinery. I have had just a little experience with it myself.
At any rate we agree that its best to follow MoCo's recomendation?
brhodea is offline
post #10 of 19 (permalink) Old 04-15-2011, 08:20 PM
allofus81's Avatar
Black oil yes that is what I said in my earlier post USED 20/50. Not familiar with NEW black oil I guess. But who knows. If the fork is dirty at the time of the new install, what other things are floating around in there to take out seals and make the forks leak? Isnt that why you have the inital engine oil change at 1000 miles? To get rid of the impuritys from the assembly process? Why not do the same on the forks? Because some operators manual tells you not too?
2000 RG fork oil change help???? Tyeglide Fluids and Lubricants 8 08-21-2014 10:30 PM
Fork Oil Change - Couple Questions kevanbo Suspensions 6 07-23-2014 11:28 AM
Clunking after Fork oil change Road08Glide Suspensions 2 05-13-2013 08:55 AM
Fork Oil change rdnkjeeper Suspensions 6 04-09-2012 10:50 AM
Fork oil change pte359 Do-IT-Yourself 15 09-14-2010 05:04 PM
