Best Way to lower 2011 FLTRU - Road Glide Forums
post #1 of 19 (permalink) Old 05-16-2011, 01:11 PM Thread Starter
I have to lower my Road Glide an inch or two. Whats the best way to do it?
I'm a a short guy (29" inch inseam) and I prefer to flat foot the bike. I was thinking Lowering the rear shocks. I'm a cruiser type of rider not too much into the twisty's.
And help would be greatly appreciated.
Tom
tomerza is offline
post #2 of 19 (permalink) Old 05-16-2011, 01:25 PM
ThunderBueller's Avatar
Easiest for the rear is Progressive 940 shocks. You get an inch lower and a better shock without having to deal with air pressure.
Tom
2010 FLTRX--Primo paint set #83
2005 FXSTB--Sold. Gonna miss it!
2003 XL1200C--Sold
2002 Buell S3T Thunderbolt--Sold and much missed.
ThunderBueller is offline
post #3 of 19 (permalink) Old 05-16-2011, 02:12 PM
jupiter's Avatar
How do the 940's ride compared to the air?
Priscilla- 11 RGU VB with FM intake, HP, DT mufflers and FM tune.
jupiter is offline
post #4 of 19 (permalink) Old 05-16-2011, 03:07 PM
Soooo much better it's not even funny. I love mine.
Tom
2003 XL1200C--Sold
post #5 of 19 (permalink) Old 05-16-2011, 04:11 PM
ichiban's Avatar
Lower the seat first
ichiban is offline
post #6 of 19 (permalink) Old 05-16-2011, 05:13 PM
skratch's Avatar
the 940s will give you the 13'' ride, with a 12'' ride height. but if you have that short of an inseam, you still won't be able to flatfoot. i had a set of stock shocks cut down at bitchin baggers to 11-1/4'', and while a lot better, i can't really flatfoot, (5'4'', with a 29'' inseam). i am also using the danny grey speed cradle which sits me down quite a bit from stock.
however, if you're willing to chance it, (i've heard)you can get an awesome ride from the 940s.
good luck
skratch is offline
post #7 of 19 (permalink) Old 05-16-2011, 05:49 PM
BigDaveOnBass's Avatar
Send a message via Yahoo to BigDaveOnBass
I'd be remiss if I didn't offer this input. Your mileage may vary.
I had a White Bros. 1" or 1 1/2" rear lowering kit on my Glide for a while, but ended up removing it because when me and the wife would ride together (and sometimes when I was by myself,) I would hear something scrubbing under the rear fender. I never figured out what it was. I removed the lowering kit and the scrubbing subsided.
Fast forward to the last couple weeks. I noticed my right turn signal/running light was out. I swapped bulbs between the left and right lights and both were good. I removed the Kuryakyn running light module and connected it stock, but the right light was still out. Since I thought I was going to need a new socket, I just went ahead to the dealership Saturday and let them look at it. What ended up being the problem was two of the clips that hold the rear light harness to the inside of the fender were damaged or missing. The harness sagged and the tire rubbed through the loom, cutting the wire to the right light. The tech had to drop the rear wheel to get to everything. He repaired the broken wire, taped up one wire where it was starting to cut through the casing, and repaired the loom, replacing both plastic clips while he was at it. I'm good to go now, but $127 lighter (and that was a hook up, as I have "people" at the dealership who know and look after me.)
Just remember if you hear a scrubbing sound, look into it right away. Don't screw around like I did.
'04 FLTRI, originally Smokey Gold, now Vivid Black, 95", S/E forged high comp 9.6:1 pistons, Andrews 37G cams, Big Boyz heads, S/E adjustable pushrods, S/E Race Tuner, S/E Stage 1 kit, V&H Dresser Duals, S/E slip ons, H-D premium oil cooler, chromed wagon wheels, Brembo/H-D front brakes, added rear engine guards, Paul Yaffe 10" OEM Monkey Bars, detachable tour pak
BigDaveOnBass is offline
post #8 of 19 (permalink) Old 05-16-2011, 07:26 PM
Bayou Glide's Avatar
Swap for my Custom - I'm 6'4" - could use the extra space.
It's not the size of the dog in the fight, but the size of the fight in the dog...
Bayou Glide is offline
post #9 of 19 (permalink) Old 05-16-2011, 07:36 PM
Wooden Nickel
Guest
Posts: n/a
Mustang makes a LowDown Touring Seat which is 1 1/2" lower than stock and the nose of the seat is 1 1/2" narrower.
post #10 of 19 (permalink) Old 05-18-2011, 10:35 AM Thread Starter
Lowering Road Glide
If I get a set of 12" 940's would that lower me 2" inches?
Thanks for the input!!
Tom
tomerza is offline
My Way - 2013 FLTRU - 57H - Cobra - Ness - TTS - V&H r0de_runr Road Glide Builds-Document your builds HERE --NEW 2 10-28-2013 10:45 PM
Best way to remove console insert, '13 FLTRU HellInABucket *General Road Glide Discussions/Pictures 11 07-16-2013 10:18 AM
Best way to lower the front fender? Xaran Paint & Bodywork Section 8 05-10-2012 12:43 AM
Best way to lower front 1" fosterp Suspensions 6 11-14-2011 05:31 AM
Best performance Pipes for fltru mkich66225 Intake and Exhaust 47 09-21-2011 10:34 AM
