New Works Performance Steel Tracker shocks - Road Glide Forums
post #1 of 4 (permalink) Old 06-15-2011, 11:32 PM Thread Starter
Send a message via Yahoo to musicman8120
Finally got my new shocks the other day. Got the Works Performance Steel Trackers with dual rate springs and the ARS system. This uses a stepped collar over the initial spring, and determines how soon the shock goes from the soft spring to the main spring, thus affecting load carrying ability. The pre-load is also adjustable. They custom make these according to your's and the passengers weight, and the approx weight of the bike. They bolted right on and lined up perfectly. I went with the 13" ones as I wanted a little more ground clearance. I can still touch the ground without issues.
I've put a few miles on solo and am really impressed with how well they handle the bumps. No jarring or bouncing. My wife recently had surgery so won't be able to check out the two-up ride for a few more weeks. The only issue I had was that my WheelDock EZ Up center stand now is too short, so I've listed it in t he classified if anyones interested. Once we can get in some two-up riding I'll report back.
2010 Scarlet Red RGC, ABS, cruise,XM radio,vented lowers, Pro Pipe, SE intake , Thundermax Auto-tune, Arc Audio 6.5's,
Road Zeppelin seat, 16" WindVest, KingTourPak w/ detachable kit, Works Performance Steel Tracker shocks.
PGR member
musicman8120 is offline
post #2 of 4 (permalink) Old 06-15-2011, 11:52 PM
Thanks for the info. I've run "Works" before on my FXRs. Great shock.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #3 of 4 (permalink) Old 06-18-2011, 07:57 PM
connector's Avatar
Thumbs up
Another one here was one of my first upgrade. Had them for 2 years now on my Roadie and they have been great. Steel trackers compared to the stock was night and day well worth a little money. Confidence going into the mountains and the ease of going solo to two up about one minute.
09 FLTR 103 Stage III
connector is offline
post #4 of 4 (permalink) Old 06-18-2011, 11:02 PM Thread Starter
I'm very happy with their performance so far. I did notice today that the much talked about " 40mph wobble " has returned. I'm wondering if the change in steering geometry caused by the 1 inch longer shocks could have brought this back. It's not as bad as it once was before the dealer tightened the head bearing, but it is back.
Also, I wonder if anyone has the standard length WheelDock EZ Up center stand. I'd like to know the distance from the center of the pivot pin to the bottom of the foot piece. I'm thinking it'd be cheaper to have a weld shop add some material to the bottom of my shorter stand than buy another one.
PGR member
Works Performance 12.6" coil over shocks $400 HogPro Parts for Sale 1 05-16-2014 07:08 PM
High Performance Stainless Steel Micronic Motorcycle Oil Filters BDMastiff Engine Related 15 09-03-2011 11:19 AM
Works Performance shocks musicman8120 *General Road Glide Discussions/Pictures 4 05-06-2011 10:24 PM
Spot GPS MEssenger/Tracker Anyone? Shrug General Off-Topic Discussions 10 04-05-2011 02:12 PM
Leaking air shocks - New Works Shocks RoadGlide5150 Equipment-RG 0 10-29-2010 04:04 PM
