Sporadic knock at idle new tw-777 cam - Road Glide Forums
post #1 of 7 (permalink) Old 10-02-2013, 06:37 PM Thread Starter
ChivoChavez321's Avatar
Last week I had a TW-777 cam installed. It is fantastic, BUT, when I first start up, the engine sounds fine. As it warms up there starts to be a sporadic "knock". Increasing RPM's and it disappears. When I picked up the bike I noticed the knock and the wrench sez its due to the new cam with increased lift, etc. I am going to take it back tomorrow and ask them again. The power of the new cam is great and cruising I am getting 49 mpg, but I hate knocks of any sort. Hope to hear from someone. Thanks
2013 Big Blue Pearl Road Glide Ultra. Monster Ovals, Jackpot Ceramic Headers, Fuel Moto Power Vision and Billet Air Cleaner, Oil Temp guage, saddle bag bumpers, 11.5" rear progressives 444, monotubes -1, Woods TW-777 cam 107 FM kit with Level B Heads, polished throttle body. 123 Torque/113HP. "Lord, help me to be half the man my dog thinks I am"
ChivoChavez321 is offline
post #2 of 7 (permalink) Old 10-02-2013, 06:41 PM Thread Starter
Sorry, posted under the wrong Forum.....HELP ADMINISTRATION!!!!!
post #3 of 7 (permalink) Old 10-02-2013, 09:36 PM Thread Starter
No opinions or ideas?
post #4 of 7 (permalink) Old 10-26-2013, 06:33 AM
I also have the 777s. They are really great. When you first start the bike it can miss a beat and actually stall. A quick restart and you are in business.
There is also a different mechanical sound at cruise. About 2200 rpm. Also, in turns, you can feel a difference in the engine coming from valve train.
That has been my experience over the last 2500 miles.
JSFRGU is offline
post #5 of 7 (permalink) Old 10-26-2013, 10:20 AM
I have 777 in my bike and that different sound while cruising at 2200 is because you are lugging your motor. These cams work5122946491 better at higher rpm I try not to let mine drop under 2600 rpm but normally ride it between 2800-3000 while cruising. The valve train will be alittle louder then stock due to the ramp design of the cams but it should not knock on start up. Sounds like a lifter is bleeding down but it is hard to trouble shoot over the internet with out some kind of video.
Jims79FLH is offline
post #6 of 7 (permalink) Old 10-26-2013, 10:36 AM Thread Starter
Upon further scrutiny, I believe what I hear coming from the ac is "reversion" and not a "knock" although that's kinda what it sounds like.
post #7 of 7 (permalink) Old 10-26-2013, 11:24 AM
Did you have any head work done? You may want to get stronger valve springs when using a high lift cam. I use a SE259E cam which has similar lift as the woods 777 cam and I run the bike at rpms in the 2000 to 2500 range with no problems.
14 FLHTK Cam Testing by Fuel Moto TW-222/555/777 fuelmoto Dyno Results 13 06-25-2014 01:35 PM
New cams woods tw 777 bigmatt1967 Engine Related 5 10-23-2012 11:09 AM
2012 Touring 103" Jackpot exh Wood TW-777 Cams fuelmoto Dyno Results 2 11-25-2011 12:45 AM
cycle-rama 575 or woods tw-777 hognit Engine Related 9 11-02-2011 04:00 PM
2012 103" Touring Testing Wood TW-777 Cams fuelmoto Fuel Moto 6 10-24-2011 04:50 PM
