Can't Decide - Road Glide Forums
post #1 of 7 (permalink) Old 06-21-2011, 10:24 AM Thread Starter
Can't Decide
Okay I need some input. I am having trouble with my air shocks ( I know everyone does). Here's my deal I can put in 50 pounds of air in the shocks take the other half out for the day and in two hours it's down to 35 pounds and it's bottoming out handling bad. I took it do the dealer they said if it holds air setting over night then it's good; well it only leaks while I.m riding 2 up. I replaced the fitting on the shocks and the fill valve. So here's my question; how much stiffer, harder is the ride with Progressive or some other shock. I don't want to jar my eye teeth out, but I've got to fix this. So what do you guys think?
scsharp2260
'09 Road Glide
PC V w/ Auto Tuner
Bub Series 7 Stealth Mufflers
scsharp2260 is offline
post #2 of 7 (permalink) Old 06-21-2011, 10:39 AM
OldNerdGuy's Avatar
I put a set of Progressive 940's on and love the ride.
OldNerdGuy is offline
post #3 of 7 (permalink) Old 06-21-2011, 11:07 AM Thread Starter
Oldnerdguy, what kind of weight are you packing if you don't mind me asking? I weigh in at 300 then you add my wife well she wont tell me but I'm thinking 190 and we bottom out. And my other problem and I guess I just have to get past it is paying that much for shocks! I didn't pay that much for shocks for my sports car!
scsharp2260
'09 Road Glide
PC V w/ Auto Tuner
post #4 of 7 (permalink) Old 06-21-2011, 11:19 AM
skratch's Avatar
before you give up on the air shocks, try pushing the collar in a little, then pushing the air line all the way in. could be they aren't fully inserted.
if that doesn't work, try taking the air line off and making sure that the end is square cut.
or you could do both, just to make sure.
only takes about 5 minutes to do.....
skratch is offline
post #5 of 7 (permalink) Old 06-21-2011, 12:04 PM Thread Starter
I put new lines on, new fittings, I even changed the oil in them. I had a '07 Ultra Glide that I put 100,000 on and never had any problems and you could only put 30 psi max in them! I just don't get it. And what erks me is the dealer just says there is nothing we can do. I've bought 4 bikes from them, you'rd think they could at least ride it with 2 people on it to see. I spent my life as a car mechanic and then a manager, if we did that in the car world, the manufacture would be having a fit and I'd loose my job. Just saying;
scsharp2260
'09 Road Glide
PC V w/ Auto Tuner
post #6 of 7 (permalink) Old 06-21-2011, 12:27 PM
It sounds like the problem is in the rear shock system I would start by removing the seat putting in the amount of air you run 2 up and then with some sandbags or something to simulate the weight start looking for leaks with a spray bottle and soapy water solution just like you would for a slow leak on a tire , may take a while but if you have a rainy day its a good way to spend it .
Eagle
Eagle is offline
post #7 of 7 (permalink) Old 06-22-2011, 01:14 PM Thread Starter
Well it seems that my wife and I must be too heavy for the factory shocks, so I am going to buy some shocks. Now I just need to figure out which ones? Anyone tried these Suspension Technologies USA F-Tech 130BB?
scsharp2260
'09 Road Glide
PC V w/ Auto Tuner
buky bars 14 or 16 malo, can't decide flattop69 Controls & Handlebars 15 09-24-2014 08:22 AM
ugh, I hate this! Can't decide which windshield. haider320 Windshields 19 06-26-2014 02:48 PM
Next Upgrade, Can't Decide... gakarl *General Road Glide Discussions/Pictures 22 08-14-2013 11:26 AM
Black or chrome? I can't decide. ctalbot6983 *General Road Glide Discussions/Pictures 24 01-06-2013 03:16 PM
in case you can't decide: Road glide or a Semi Trailer GuyHD *General Road Glide Discussions/Pictures 11 06-11-2012 03:27 PM
