Is it possible?? - Road Glide Forums
post #1 of 2 (permalink) Old 10-11-2013, 05:19 PM Thread Starter
Venomized's Avatar
Is it possible??
I just put new tires on my 07 and am wanting to swap on 12" oem shocks instead of the 13s that are on there. My worry is this...
Dunlop D402s are 25.71" diameter with 11/32" tread depth
Michelin 140/90B16 i put on is 26.61" diameter and 5/16" tread depth
So i actually have a tire that is .9" taller. Is it going to be possible to bring it down that 1" im wanting with no ill effects? I know sidewall clears all the way around so no worries there, just dont know if it will hit bein that the tire is almost an inch taller anyways.
Thanks ahead of time
'07 Pewter Pearl
Road Glide or No Ride!
Venomized is offline
post #2 of 2 (permalink) Old 10-11-2013, 07:04 PM
faststan's Avatar
Your math is suspect. Should be .9" not .09". Only 1/2 of that is above the axle centerline. That gives you .45 " larger. Should not be a problem with 12" shocks.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
possible oil leak Roadglide Mike *General Road Glide Discussions/Pictures 2 03-20-2011 04:49 PM
Pre 2008 Seat Conversion Possible ? joerun26 Seating: seats, backrests 2 03-18-2011 11:02 PM
Possible loose triple tree bearings on 09 RG j schleifer Troubleshooting for Road Glides 3 01-28-2011 08:46 AM
Possible loose triple tree bearings j schleifer Troubleshooting for Road Glides 1 01-26-2011 06:58 PM
Dude makes it possible to listen to Lady Gaga. DreamRider *General Road Glide Discussions/Pictures 13 11-17-2010 09:08 PM
