Brake lines and monotubes - Road Glide Forums
post #1 of 4 (permalink) Old 10-13-2013, 12:01 AM Thread Starter
Stag556's Avatar
I tried searching but didn't find the specific answer I'm looking for so I apologize in advance if this has been answered elsewhere.
With -2 monotubes installed, how do te front brake lines sit? I notice that at stock height, there seems to be quite a bit of slack. When the front end is lowered, it would seem there would be an excess of brake line.
Anyone have any insight on this or possible solutions? I know many ppl use te monotubes so I'm sure this is a common issue.
I was looking at buying the magnum shielding lower brake assembly but don't want to if it will be too long.
Thanks in advance.
Stag556 is offline
post #2 of 4 (permalink) Old 10-13-2013, 01:25 AM
Bluchevypick's Avatar
Subscribed. I have tons of slack on mine.
Bluchevypick is offline
post #3 of 4 (permalink) Old 10-13-2013, 09:37 AM
JJSW1283's Avatar
I have extra slack in mine after the -2 drop. From the calipers to the T block. Isnt really causing any issues though. Guess the only way around it is to have custom lines made up.
JJSW1283 is offline
post #4 of 4 (permalink) Old 10-13-2013, 09:55 AM
mocotom's Avatar
Even with the 2" drop, I think the fork tube stops that limit the full extension remain the same. Although rare it is still possible to get maximum extension which would require stock length brake lines.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
Harley Brembo Brake Calipers shells & Brake lines bykw2 Parts for Sale 1 06-13-2018 05:22 AM
Lowered front end and brake lines dgfltru Suspensions 0 05-16-2012 02:07 PM
Cables and Brake Lines BigDum Controls & Handlebars 5 02-15-2012 12:24 AM
Brake and clutch lines fosterp Controls & Handlebars 2 01-06-2012 09:03 AM
Question for those that changed out to poly bushings and brake lines leeinmemphis Controls & Handlebars 8 08-02-2011 09:59 PM
