Front end shake - Road Glide Forums
post #1 of 25 (permalink) Old 10-14-2013, 10:21 PM Thread Starter
Front end shake
Having front end shake on my 2011 fltrx. high speed in turns. I have proper air inflation in tire. Ive heard the steering stem bearings are notorious for needing adjustment. Could this be the culprit? Cant find thread on this here. Also manual says i need to check fallaway. Is this an important part of this? Has anyone photo documented the service here?
THEMASTERDESTROYER is offline
post #2 of 25 (permalink) Old 10-16-2013, 06:21 AM
SmokeyJoe's Avatar
Have you ruled out tire balancing?
SmokeyJoe is offline
post #3 of 25 (permalink) Old 10-16-2013, 10:20 AM Thread Starter
i would say yeah. only wobbles in turns
post #4 of 25 (permalink) Old 10-16-2013, 11:47 AM
JJSW1283's Avatar
I had this issue as well, and also wobble going straight. I adjusted the steering head bearing to specs. Cleared up the straight wobble, but still off in corners. I thought I was running the right air pressure of 36psi, but after the install of a 21 and metzler 880, people recommended 50 psi. Set pressure to 50psi, everything is great now.
JJSW1283 is offline
post #5 of 25 (permalink) Old 10-16-2013, 12:51 PM
Tire pressure depends on the tire brand and size. Look on the sidewall, it is always on every tire and rarely are two different brands or sizes the same.
HogPro is offline
post #6 of 25 (permalink) Old 10-16-2013, 01:41 PM
bulldog68's Avatar
I had this problem and to some extent it was still there when I sold it.....better front and rear suspension will help, wider, better front tire, helps......IMO, and from adding a bag in the passenger seat.....they have too much rear percentage of weight or something ?...because it got worse the more weight you carried or faster you went......I only think this way from years of running dirt cars.
bulldog68 is offline
post #7 of 25 (permalink) Old 10-16-2013, 11:13 PM Thread Starter
fltrx. stock rim and tire. 36 psi
post #8 of 25 (permalink) Old 10-17-2013, 11:22 AM
Boatnut's Avatar
pressure
36 is too low.. 40psi COLD will change your bike in a good way. Also reduce tendency to cup.
Boatnut is offline
post #9 of 25 (permalink) Old 10-19-2013, 10:37 AM Thread Starter
I'll give it a shot ! much easier than taking apart trees to do bearing adjustment. wish someone photo documented that process. manual says to "fashion " a bearing adjuster tool from drill rod
post #10 of 25 (permalink) Old 10-19-2013, 10:53 AM
Mine gets the wobble every time I let it get to 36 psi. At least 40psi in the rear stock Dunlops.
mid-speed, front end shake groupw Troubleshooting for Road Glides 11 03-24-2013 06:21 PM
Front end shake t-roc *General Road Glide Discussions/Pictures 35 06-29-2012 10:08 AM
Slight front end shake/wobble at low speed smitty901 Troubleshooting for Road Glides 2 04-28-2011 11:59 PM
2011 front end shake smitty901 Troubleshooting for Road Glides 1 04-14-2011 01:18 AM
Front end shake kuma *General Road Glide Discussions/Pictures 12 03-17-2011 08:09 PM
