Arlen Ness Dual Brake Caliper Setup - Road Glide Forums
post #1 of 13 (permalink) Old 10-15-2013, 02:43 PM Thread Starter
Q-Hog's Avatar
Does anyone has any experience or info on the Arlen Ness Dual Brake Caliper (single side fork) SetUp..? If so, please share your pros & cons.. Thx
Q-Hog is offline
post #2 of 13 (permalink) Old 10-15-2013, 03:05 PM
JJSW1283's Avatar
Ive seen them. No experience, but hope they have some kind of special rotor to take that kind of heat without warping.
JJSW1283 is offline
post #3 of 13 (permalink) Old 10-15-2013, 05:50 PM Thread Starter
Q-Hog's Avatar
Thx JJ.. I'm concern as well of the amount of heat two calipers might effect the rotor. Because the I think the kit doesn't include the rotor.
Q-Hog is offline
post #4 of 13 (permalink) Old 10-15-2013, 09:05 PM
911Shark's Avatar
Have since 6/2012. Over 12k. Love em. Braking great. They look great. Nobody has them. Cons: if u have PM calipers, hv to machine spacers. But glad I did, gets lots of compliments and they work
2015 CVO/SEPRT/Arlen Ness Big AC/NO Cats/nada mas
2004 SE 103"/Branch P&P heads/Branch 595 Cams/Diamond Cut/SE 6speed/SERT/2n1 Ceramic ThunderHeader/Progressive Monotube F, 444 R
911Shark is offline
post #5 of 13 (permalink) Old 10-15-2013, 09:32 PM Thread Starter
Q-Hog's Avatar
Thx for the info.. I've seen them in magazines. Any problems while braking pull to or pulling down on one side while braking.. I want to use my stock caliper.
Can you post a pic of your setup. Thx.
Q-Hog is offline
post #6 of 13 (permalink) Old 10-15-2013, 10:19 PM
RichieRich's Avatar
Attachment 64650
Q, you know I got nothin but love for you right but that's hideous. SMH
Sent from Motorcycle.com App
2013 BBP FLTRX
RichieRich is offline
post #7 of 13 (permalink) Old 10-15-2013, 11:04 PM Thread Starter
Q-Hog's Avatar
It's homework buddy,, 8-) but thx..
Q-Hog is offline
post #8 of 13 (permalink) Old 10-15-2013, 11:20 PM
Shark of the Month August 13
SIC_26's Avatar
Not that I know anything, but, the point of going single sided is to show off the wheel.......two calipers is only going to clutter and cover up the left side (and a bitch to clean up around the calipers) there's no braking problems with a single sided setup with a single 6-piston caliper
Doing homework is never a bad thing, but if it comes down to money......your gonna buy a single matching rotor anyway and selling the stock late model rotors and calipers will more than pay for a new HHI (or PM) 6 piston caliper, I usually get $400 for the brembo setups
13" cog drive or FULL floating rotor and a 6 piston caliper is my vote, tried and true setup in both looks and performance :thumbup:
SIC_26 is offline
post #9 of 13 (permalink) Old 10-15-2013, 11:28 PM Thread Starter
Q-Hog's Avatar
Sic, Thx a lot for the info. I'm just gathering info and planning several ways to go. I'm in no rush..
Q-Hog is offline
post #10 of 13 (permalink) Old 10-15-2013, 11:34 PM
SIC_26's Avatar
Depending on the wheel you choose.....if you ever do LOL....will dictate the type of rotor you can go with, if you go with a matching rotor. Cog drive takes the cake, and true full floating is a close second. My recommendation would be to stay away from the 1 piece stamped rotors
When it comes to brakes, you do get what you pay for
Food for thought if nothing less
SIC_26 is offline
Arlen Ness Chrome Front Brake Rotors bykw2 Parts for Sale 1 05-12-2017 08:48 PM
Arlen Ness Black Deep Cut Brake pedal vlgolf Parts for Sale 0 03-24-2016 09:35 AM
14" Dual Disc Rotors by Arlen Ness Hillglide *General Road Glide Discussions/Pictures 1 02-12-2016 11:13 PM
Arlen Ness Deep Cut/ 9/16 front brake cylinder Dokushin Wanted! (Buy or Trade) 0 01-29-2013 07:01 PM
Need advice on one caliper setup fltrx 2010 440sundancer Troubleshooting for Road Glides 10 05-04-2010 06:57 PM
