Front fork change - Road Glide Forums
post #1 of 10 (permalink) Old 10-20-2013, 03:38 PM Thread Starter
eldridgetom's Avatar
Front fork change
I'm wanting to change my front forks for gloss black. Other than fork oil, are there any additional kits, gaskets, etc that I need. Dealership says yes.
eldridgetom is offline
post #2 of 10 (permalink) Old 10-20-2013, 03:49 PM
JJSW1283's Avatar
You need to get the progressive monotubes while you have them broke down. You'll thank me later
JJSW1283 is offline
post #3 of 10 (permalink) Old 10-20-2013, 03:57 PM Thread Starter
I have considered that actually. I've heard a lot of good things on here about them.
What else do I need other than the forks and fork oil though? I have found gloss black forks for $150 vs Harley's $499 price tag...but then dealer said I have to have other stuff.
post #4 of 10 (permalink) Old 10-20-2013, 04:08 PM
you will need fork seals , and possibly new bolts for the dampers in the bottom of the forks.
When I installed my monotubes iI could not get the old bolts loose it was easier to drill the head off carefully and get new bolts and washers for under $5 .
look here http://www.shopronniesharleydavidson.com/ under the oem parts finder for your year and see what parts are involved in what your doing.
Eagle
Eagle is offline
post #5 of 10 (permalink) Old 10-20-2013, 04:14 PM
JayKS's Avatar
There's no better opportunity then now to go with monotubes. I'd seriously consider spending the extra dollars to do it now.
You'll also need fork seals.
You might also think about cowbells if you haven't already. Can't have nice new gloss black fork legs underneath the cheap tin stock cowbells.
JayKS is offline
post #6 of 10 (permalink) Old 10-20-2013, 04:38 PM Thread Starter
Thanks guys! May have to put this project on hold as I'm having to get new tires today...I love my harley, but damn the cost to own!
post #7 of 10 (permalink) Old 10-20-2013, 05:58 PM
sj01fltri's Avatar
when i changed mine over to gloss black its a 2012,the parts people said that i needed a kit it was over a $100 it came with all new bushings,seals bolts,ect,they said that was the way HD sells it for the 12,so i got just fork seals for a 10,same part as the 12 seals by the way,if you look at the part # for the lower legs the part # hasnt changed in years,the seals worked great ,no need to replace the bushings with only 750 miles on them,didnt know any thing about the monotubes at that time, wish i had,thats the one thing bad about this forum,the more you read,the more you learn and the more you spend.
sj01fltri is offline
post #8 of 10 (permalink) Old 10-20-2013, 07:44 PM Thread Starter
Did you DIY or get the dealer to do it? Dealership quoted $350 labor.
post #9 of 10 (permalink) Old 10-20-2013, 07:58 PM
sj01fltri's Avatar
Did it myself,its not that bad just take your time.
post #10 of 10 (permalink) Old 11-07-2013, 10:06 PM
tkbalt's Avatar
I had mine powder coated black, installed Traxxion Dynamics AK-20's, Yaffe Yaxle and Sliders, and yes - you will need new fork seals. See photos in my album.
Als0 - A nice addition:
http://www.kustombaggers.com/Fork-N-...logId=-1795#/0
tkbalt is offline
To change or not to change them, that is the question Steelerdude1 *General Road Glide Discussions/Pictures 2 07-18-2016 06:41 PM
Lifters: to change or not to change BigNorm Engine Related 14 01-19-2016 08:50 AM
Front fender damage after fork oil change hoosierboarder Suspensions 15 08-01-2015 09:04 AM
Fork Change Question Roadie09 *General Road Glide Discussions/Pictures 1 12-04-2010 08:31 PM
Fork oil change pte359 Do-IT-Yourself 15 09-14-2010 05:04 PM
