HHI Raked Tree For 23" Wheels... - Road Glide Forums
post #1 of 7 (permalink) Old 11-07-2013, 12:38 PM Thread Starter
Q-Hog's Avatar
How does HHI 23" rake tree compare to Pickards?Thx
Q-Hog is offline
post #2 of 7 (permalink) Old 11-14-2013, 08:42 PM
CustomGlide's Avatar
Send a message via AIM to CustomGlide
The Pickard Is A Little Beefier With A Better Clamping System And Can Be Purchased In Black Anodized. Both Are Great. I Have The Hhi(26" Wheel) And Love Mine. Straight As An Arrow And Easy To Install.
CustomGlide is offline
post #3 of 7 (permalink) Old 11-14-2013, 08:49 PM Thread Starter
Q-Hog's Avatar
Thx for your input. I was contemplating on exchanging the Pickard for the HHI.
Q-Hog is offline
post #4 of 7 (permalink) Old 11-14-2013, 09:05 PM
However the HHI uses rubber forks stops as opposed to the aluminum stops on the Pickard kit. The only guy I know who has used both said the HHI rides better due top the rubber (or maybe urethane) fork stops.
HogPro is offline
post #5 of 7 (permalink) Old 11-16-2013, 07:47 AM
TreeLimb's Avatar
Custom glide what else did you do to get the 26 on the HHI tree. I want it but don't want to cut up a new bike.
TreeLimb is offline
post #6 of 7 (permalink) Old 11-16-2013, 09:56 AM
Shark of the Month August 13
SIC_26's Avatar
If you don't want to cut your frame (preferred method) , Kewl Metal (has its pros and cons) would be your best option....Arlen Ness, Tricky trees, etc that say you can run a 26 with just they're trees isn't the route you want go. The wheel with "fit" but you will be let with no suspension travel = shitty ride
SIC_26 is offline
post #7 of 7 (permalink) Old 11-16-2013, 11:57 PM
TreeLimb's Avatar
Good look Sic, just not sure if I'm ready to cut it. Want the 26 but probably will go 23 and a tree. Then knowing me when it comes to it I may just jump abroad the 26 crew!
TreeLimb is offline
23" wheel front end raked question bigshaqa Wheels and Tires 3 10-19-2016 08:22 AM
Just installed new 23" w/HHI triple trees Itzlen Wheels and Tires 128 11-28-2014 08:57 PM
23" on a shark with HHI weld in neck and trees anyone? HogPro *General Road Glide Discussions/Pictures 1 05-27-2014 06:44 PM
21" front with aftermarket raked triple tree? Tatude Wheels and Tires 22 05-06-2014 06:48 PM
BRAND NEW HHI 7* Trees for 21" or 23" wheel Peterod45 Classifieds Archive (3 months old+) 2 07-24-2012 03:16 AM
