Monotube issue - Road Glide Forums
post #1 of 52 (permalink) Old 11-27-2013, 08:58 PM Thread Starter
Stag556's Avatar
Monotube issue
I just completed my install of many upgrades, one being monotubes. I opted to go with the -2" up front.
Here's my issue. As soon as I backed the bike off the lift and went over the hump to exit the garage, I hear and feel a clunk up front.
I put it back on the lift and rechecked every bolt for tightness. I'm very tedious and went very slow with my install. I didn't use any c-clips and used the two springs on the monotubes, as the instructions stated.
I can't for the life of me figure out what could be wrong. Anyone had this issue or have any tips. I'm dreading takin this thing apart again.
Stag556 is offline
post #2 of 52 (permalink) Old 11-29-2013, 05:53 PM Thread Starter
Stag556's Avatar
Anyone with any insight?
Stag556 is offline
post #3 of 52 (permalink) Old 11-29-2013, 06:24 PM
Are you sure you installed right ? I cant speak for the lowering kit Mono tubes ,but the orginal height Mono tubes that I installed a year ago, work great. No thump.
There's also a sequence on re tighting everything back up on the forks &Tripple trees and torque is very important.
also ,you might want to share what your working on. 98s are a lot different than a 13s.
post #4 of 52 (permalink) Old 11-29-2013, 08:12 PM
JsGlide's Avatar
You have to install the c-clips. I had the same issue. I tore them down sent them back to be checked. Progressive told me to install the c-clips. I installed all the clips and have not had an issue yet.
JsGlide is offline
post #5 of 52 (permalink) Old 11-29-2013, 08:44 PM
I only installed one clip per side. Progressive told me it was okay to not use any if I wanted a less firm ride . I did have the oem height kit tho, not the lowering one.
post #6 of 52 (permalink) Old 11-29-2013, 09:14 PM Thread Starter
Stag556's Avatar
Really? Well that could explain a lot. Their instructions say for a -2" drop, use both springs and no c clips. I tried contacting progressive today but they are closed for the holiday so I'll give them a shout Monday.
Sorry, it's a '13 RGC.
Stag556 is offline
post #7 of 52 (permalink) Old 11-29-2013, 11:35 PM
mjsdouble's Avatar
I only have about a 100 miles on mine. I'm at -2 without any clips per instructions. I haven't noticed any problems at all. I hope you get it worked out quickly.
mjsdouble is offline
post #8 of 52 (permalink) Old 11-30-2013, 12:09 AM
I have over 20k miles on mine.... -2" no C clips, no problems. Do you know the manufactured date on your kit? Just asking, I remember some people had issues with a clunk when the lowered kits first hit the market, I don't know what Progressive did to solve the problem.
Sent from my SPH-L710
post #9 of 52 (permalink) Old 11-30-2013, 12:49 AM Thread Starter
Stag556's Avatar
I'm seriously puzzled. I've been very thorough assembling these forks. Can't imagine what could be wrong.
Just have to wait until Monday to talk to progressive.
Stag556 is offline
post #10 of 52 (permalink) Old 11-30-2013, 08:25 PM
JsGlide's Avatar
When I called Progressive they said they got the clunk fixed and it came from the shocks leaking. They said that was not the case with mine or any of the new shocks. They asked me if I was a big guy which I am 270 pounds. They said the shock is bottoming out. I put the clips in didn't notice any difference in height. The shocks are a little stiffer but beats that clanking sound.
JsGlide is offline
Progressive monotube story BLACKHAWK Suspensions 1 11-07-2011 12:42 AM
progressive monotube cartridge system THEMASTERDESTROYER Suspensions 3 09-25-2011 09:57 PM
Progressive monotube on RGU jupiter Suspensions 11 09-08-2011 09:58 PM
Progressive Monotube bigbrainbob Suspensions 12 04-23-2011 04:32 PM
Proggressive Suspension Monotube Kit akjeff *General Road Glide Discussions/Pictures 6 07-30-2010 10:47 AM
