Front Suspension - Road Glide Forums
post #1 of 8 (permalink) Old 08-12-2011, 01:20 PM Thread Starter
Not_A_CVO's Avatar
Front Suspension
Now that I am finally happy with my rear suspension, time to tweek the front. I would like the revalve and go 1" down. Any seguestions? I have Legend Air Ride in the rear.
09' Road Glide
Not_A_CVO is offline
post #2 of 8 (permalink) Old 08-12-2011, 01:36 PM
http://www.progressivesuspension.com/dropin/index.html
This is a qualitiy lowering kit by a trusted name
twowheel99 is offline
post #3 of 8 (permalink) Old 08-12-2011, 01:40 PM
Moderator
BLKNCr6's Avatar
+1...put two of these into...ah...well..."friends" batwings...geeze did I use friend and batwing in the same sentence?...
Really, a quality product and a nice ride when done...
...and I used to think my Sportster was heavy...
A Harley will get you through times of no sex, better than sex will get through times of no Harley.
2011 FLTRU
SE Heavy Breather
V&H Monster Ovals
SE Pro Super Tuner to make the above play nice together.
BLKNCr6 is offline
post #4 of 8 (permalink) Old 08-12-2011, 10:29 PM
FLSTFI Dave's Avatar
09' Road Glide
If you want to lower it and improve the handling, reduce front end dive under hard braking and such I would go with the Progressive mono tube fork cartrige kit. http://www.progressivesuspension.com...ube/index.html
It is available in stock and 1 inch lower.
It greatly improved the handling on by bike.
It will be on of the very first improvements I do on the next bike.
2018 FLTRXSE Gunship Gray
2013 FLHRSE5 Diamond Dust / Obsidian 138HP and 140 torque
FLSTFI Dave is offline
post #5 of 8 (permalink) Old 08-13-2011, 07:18 PM
tj316's Avatar
I've ran Progressive monotubes on last 2 bikes , they work well
tj316 is offline
post #6 of 8 (permalink) Old 08-14-2011, 10:07 AM
IMHO, if you want the best go with Traxion AK20's.
http://www.traxxion.com/
HogBreath is offline
post #7 of 8 (permalink) Old 08-14-2011, 06:51 PM
tj316's Avatar
I looked hard at the Traxxion and still may get them , I talked to Max the owner 3 or 4 times , the Goldwingers love them , Max suggested I go to the CVOforum and read what Harley riders had to say , I went there and found maybe 40 guys who were using them , most went from stock to the Traxxion and claimed it was worth every penny about $1100 , however there were about 4 that went from stock to Progressive Monotubes to Traxxion , all 4 said if stock was a zero for reference point for $300 monotubes got you to about a 7 , for $1100 Traxxion got you to about a 9 , all told me for the money the Progressive was the best value and they would not buy the Traxxion again , I then talked to a guy who just put Ohlins on his rear and Monotubes up front on hdforums and he said the Ohlins were a 10 and the monotubes were a 9 for performance and a 6 for comfort as they didn't absorb the bumps like the Ohlins and a 7.5 over all , I had just bought my Ohlins and after hearing this went with the monotubes up front , so far I love the combo however Max said he is putting the Traxxion in a shop Harley that you can demo , I will probably take a ride to Atlanta and check it out
tj316 is offline
post #8 of 8 (permalink) Old 08-15-2011, 04:19 PM Thread Starter
Not_A_CVO's Avatar
Ordered the Progressive system today.......
Front suspension 'rough' mpears53 Suspensions 13 08-01-2017 07:37 AM
Race Tch Front Suspension with Gold Emulators RGKen Suspensions 3 05-19-2013 06:59 PM
New Progressive suspension front & rear. TRUBlue Suspensions 16 04-18-2013 10:29 PM
Evo front air suspension thedude Suspensions 4 12-31-2012 03:55 PM
front suspension jscal Troubleshooting for Road Glides 1 06-21-2011 08:33 PM
