8 speaker set up help - Road Glide Forums
post #1 of 22 (permalink) Old 12-18-2013, 03:10 PM Thread Starter
pacmanrr's Avatar
Fellas I need some help from the audio gurus. Im upgrading to an eight speaker set up over the winter and im not sure which amp or amps to run to properly power this set up.
BTW Im running 4 6.5 pioneers a pair of Alpine 6x9s and a pair of super tweeters.
pacmanrr is offline
post #2 of 22 (permalink) Old 12-18-2013, 03:53 PM
ITOLDU's Avatar
You could run any number of 4 ch amps, if you want it to fit in the inner fairing then the JL Audio XD 400/4 would work. Every other 4 channel is going to be larger and most likely require you mounting it in the saddle bag.
ITOLDU is offline
post #3 of 22 (permalink) Old 12-18-2013, 04:31 PM
torqu's Avatar
2 ohm or 4 ohm set up?
torqu is offline
post #4 of 22 (permalink) Old 12-18-2013, 04:44 PM
Q-Hog's Avatar
If you want serious audio on a bike, it needs to start with the amp & where you are considering mounting your amp, since the location is limited. Then go from there.. JMO
Q-Hog is offline
post #5 of 22 (permalink) Old 12-18-2013, 05:37 PM
Admin
BillyBob's Avatar
I'm running j&m 4 speaker kit and like it.
Give John at j&m a call. I know they have some new amps and speakers out.
Good luck !
Sent from Motorcycle.com App
BillyBob is offline
post #6 of 22 (permalink) Old 12-24-2013, 04:49 PM
Deadstroke's Avatar
I am using the Rockford fosgate 300x4 I mount them in the fairing.. Love them they work great!!!! Have 2 of them in the fairing
Deadstroke is offline
post #7 of 22 (permalink) Old 12-24-2013, 04:57 PM
RichieRich's Avatar
The new Soundstream Picasso 520D is 4 channel and fits in the fairing. For 8 speakers I'd used two. I'm cautious about running a motorcycle amp at 2 ohms due to limited cooling room, no cooling fan, and long hours playing at high volume. I have four speakers and a JL 400x4 in the fairing but that required major modification including grinding on the heat sink.
2013 BBP FLTRX
RichieRich is offline
post #8 of 22 (permalink) Old 12-24-2013, 04:58 PM
09Sharknose's Avatar
The hawgwired amps can handle 4x4ohm speakers and they sound awesome. 100w continuous to each, and two or more of them will fit in your fairing. I'm not sure how much power your super tweeters can handle, but they sound like the kink in the armor to me.
09Sharknose is offline
post #9 of 22 (permalink) Old 12-24-2013, 08:22 PM
RichieRich's Avatar
Agreed about the tweeters. Guaranteed not to handle the same amount of juice as the rest
2013 BBP FLTRX
post #10 of 22 (permalink) Old 12-24-2013, 08:41 PM
OKBigD's Avatar
I'm going to be running 2 sound stream pn2.350d 175x2 @ 2 ohms... Only running 4 speakers but they're polk MM's which are 2 ohm each.
Got my fingers crossed that it will sound great. So far I'm excited about these amps they're just as small as the RF pbr.. Only 115$ each on Amazon.
OKBigD is offline
Help with Hawg Wired Set up 2016CTRoadGlide Audio 6 06-26-2017 06:55 AM
Best modest cost 2 speaker in the fairing set up. dvanlue Audio 27 01-15-2015 09:23 AM
Best amp/speaker set up CSM11 Audio 38 06-24-2013 09:11 AM
8 Speaker Set up chinbagger Audio 14 03-26-2012 11:46 PM
Best Sound From A 2-Speaker Set-Up??? HoboCoastie Audio 46 03-19-2012 08:13 AM
