Rockford Fosgate PBR300X2 Punch 300-Watt 2-Channel Boosted Rail Amplifier* - Road Glide Forums
post #1 of 11 (permalink) Old 12-28-2013, 08:40 AM Thread Starter
Just wondering how this amp or its brother (4 channel) held up for you guys that ride over the road and in the rain.
post #2 of 11 (permalink) Old 12-28-2013, 10:03 AM
stripclub's Avatar
I have 2 mounted in my fairing an have had no problem with them, over the road, in the rain, and in heat of the summer. The key is to get the gains adjusted properly, and if using a factory HK head unit, turn the volume up to 3/4 and use that as your max volume to adjust the amp gains accordingly. The HK head unit gets real distorted output signal above 3/4 volume, so it gives a distorted input into the amp which output from amp will be a distorted signal into the speakers, and also creates more heat in amps. RF amps are solid, and dependable, as long as installation and adjustments are correct.
stripclub is offline
post #3 of 11 (permalink) Old 12-28-2013, 10:04 AM
chromedome's Avatar
I don't do a bunch of rain riding 'cause I'm in SoCal but after 15000 miles it still works perfectly.
2012 Road Glide Ultra (SOLD) & 2015 BMW R1200RT
chromedome is offline
post #4 of 11 (permalink) Old 12-29-2013, 01:50 AM
steel breeze's Avatar
Stripclub, I'm looking at this amp, and I just got a Sony head unit. any suggestions on adjusting the gains with that set up? Also have Hogtunes 5x7 speakers in the fairing. Thanks for any advice.
2005 Shark. Madstad shield, Progressive Mono tubes, Kenwood KMR-M315 deck, Alpine SPR-60C speakers, Trask V-line bars, V&H Pro Pipe, S&S cams, 21" Fat Spoke, extended bags, SE air cleaner.
steel breeze is offline
post #5 of 11 (permalink) Old 12-29-2013, 08:27 AM
kouack's Avatar
I had mine for one summer, few rides under heavy rain, hook to the HK unit with a set of polkaudio mm6.5 very happy.
kouack is offline
post #6 of 11 (permalink) Old 12-29-2013, 08:41 AM
I've had both the 300×4 and the 300x2, both are ok, IMO the 300x2 is the better of the two, no problem with rain, etc. My gripe with the amps was heat and power supply. For the price they are good, I personally would go with Soundstream for the same price range, I guess it kind of like do you want Ford or Chevy, both get the job done.
Sent from my SPH-L710
post #7 of 11 (permalink) Old 01-01-2014, 12:17 PM
PA-SILVERBACK's Avatar
I have both mounted in My fairing.. I had to have the x4 replaced due to corrosion , It was warrantied without any problems, But it was also never exposed directly to any water .
PA-SILVERBACK is offline
post #8 of 11 (permalink) Old 01-01-2014, 12:38 PM Thread Starter
Amazon got them for $ 139
post #9 of 11 (permalink) Old 01-01-2014, 04:21 PM
This may be a dumb question, but can I run a four channel amp with just my front speakers? Reason I ask is because all I keep finding on eBay is the four channel amps. Thanks.
post #10 of 11 (permalink) Old 01-01-2014, 04:44 PM
Not a dumb question at all. Yes you can use a 4 channel amp for just two speakers.
Rockford Fosgate PBR300X2 + JM Rokker review modot66 Audio 17 01-14-2016 09:25 PM
For Sale: PBR300X4 Punch BRT 300-Watt 4-Channel direwolf Parts for Sale 6 01-12-2015 09:24 AM
Rockford Fosgate Punch PBR 300x2 danko Parts for Sale 1 12-31-2014 12:02 PM
Rockford Fosgate Punch PBR300X4 4-channel Amplifier Sealdoggy Miscellaneous for Sale 0 11-12-2014 01:33 PM
Rockford Fosgate PBR300X2 cowboyjam2000 Audio 16 09-04-2012 04:48 PM
