Mounting Crossover in rear bags - Road Glide Forums
post #1 of 10 (permalink) Old 12-30-2013, 08:39 PM Thread Starter
OKBigD's Avatar
So I'm getting ready to mount my 6x9 Polk MM's in my Hog Tunes Speaker Lids. Now I have to figure out the best way to mount the passive crossover in the bags (probably 3"x3". Velcro or double sided tape seems obvious but I'm worried about them staying stuck during hot weather..
I was thinking of making some kind of mounting plate that the bag screw goes through that attaches to the frame... (upgraded Bag hardware).
Any thoughts or ideas from the pro's on what will and won't work.
OKBigD is offline
post #2 of 10 (permalink) Old 12-30-2013, 10:10 PM
bpt-bagger's Avatar
If you're amp is being installed inside the fairing I would mount the x/overs inside the fairing shrink wrap the speakers leads run then down the back bone to the speakers terminals. Either way if you're mounting you're amp inside the fairing you're gonna have to run wires down to them.
bpt-bagger is offline
post #3 of 10 (permalink) Old 12-30-2013, 10:10 PM
I have the Polk MMs in my lids now, I simply used the two sided adhesive they came with and haven't had a problem in the year they've been there.
Sent from my SPH-L710
post #4 of 10 (permalink) Old 12-30-2013, 10:16 PM
bpt-bagger's Avatar
I used Deutsch connectors to make taking my bags on and off a breeze.
post #5 of 10 (permalink) Old 12-31-2013, 07:08 AM Thread Starter
OKBigD's Avatar
Did you mount them on the backside of the lid or on the side of the bags? Maybe I'll give the double sided tape a try.
I've got 2 deutsch connectors that I'm wiring under each of the side covers to help make saddlebag removal easier.
OKBigD is offline
post #6 of 10 (permalink) Old 12-31-2013, 07:25 AM
Mischief's Avatar
+1 with an addition. On several projects which I used 2-sided adhesive, I have also added a thin bead of black silicone. Never lost a part and I can still peel the parts off if I need to change anything.
2012 FLTRU
Mischief is offline
post #7 of 10 (permalink) Old 12-31-2013, 07:27 AM
On the backside of the lid right behind the speaker.
post #8 of 10 (permalink) Old 12-31-2013, 09:42 AM
Peewee's Avatar
I mounted my crossovers on the inside of the lid, under the teather strap. Can't really be seen when the bag is open, mounted with 2 sided tape, and no issues, been on about a yearish, and took the beating out to SWIII and the heat
"Know Thyself"
Peewee is offline
post #9 of 10 (permalink) Old 12-31-2013, 09:48 AM Thread Starter
OKBigD's Avatar
Thank you guys.... This is exactly where I was thinking of mounting mine... Besides the double sided tape that comes with the MM's any recommendations on the best tape or Velcro that will hold up to heat?
OKBigD is offline
post #10 of 10 (permalink) Old 12-31-2013, 10:42 AM
JJSW1283's Avatar
3m grey. Not the white.
JJSW1283 is offline
Mounting bracket for Adjustable Rider Backrest Mounting Kit Part Number 52596-09A Oldbie Wanted! (Buy or Trade) 0 08-03-2017 09:24 PM
Inner fairing speakers wired in series using crossover Biljac Audio 7 06-02-2013 10:59 PM
09 headpipe and crossover with heatshields MoRob Classifieds Archive (3 months old+) 0 07-24-2012 04:54 PM
S&S crossover duals for 95-11 touring TobyJ Intake and Exhaust 3 11-28-2011 12:12 PM
