PYLE PLMRKT4A 6.5 inch 4-Channel Waterproof MP3/iPod Amplified Marine Speaker System - Road Glide Forums
post #1 of 10 (permalink) Old 01-03-2014, 08:28 AM Thread Starter
laserman's Avatar
Other possibility, just not sure of quality, so feedback is welcome.
laserman is offline
post #2 of 10 (permalink) Old 01-03-2014, 11:37 AM
kouack's Avatar
Pyle is known for real low budget stuff, doesn't worth the time to remove the fairing to install that stuff , you will have to buy new equipement very shorthly after.
kouack is offline
post #3 of 10 (permalink) Old 01-03-2014, 11:42 AM
Unless you're really cheap, I'd stay away from Pyle, I wouldn't use it on my bike if someone gave it to me free. .... but that's just my opinion.
Sent from my SPH-L710
post #4 of 10 (permalink) Old 01-03-2014, 12:11 PM
ERod62's Avatar
Also not properly water sealed even if say so. Check You Tube ratings.
ERod62 is offline
post #5 of 10 (permalink) Old 01-03-2014, 12:46 PM
Big Daddy Recon's Avatar
I did a write up on this very set up
yeah here it is
https://www.roadglide.org/showthread.php?t=99897
2008 Harley FLHTCUI (MABLE) 50k+)
2011 Harley FXDWG (TRADED) 10K miles)
2013 Harley FLTRX (LUCIFER)(DECEASED) last 3 of VIN = 666
Big Daddy Recon is offline
post #6 of 10 (permalink) Old 01-03-2014, 12:52 PM
Bandit 7's Avatar
I have pyle stuff in my boat and its not very good quality. While it works for me on the boat to listen to the race on Sundays while fishing, I would never consider it for my bike.
Bandit 7 is offline
post #7 of 10 (permalink) Old 01-03-2014, 12:53 PM
worked fine after being dipped in water.
post #8 of 10 (permalink) Old 01-03-2014, 12:54 PM
I would have to +1 this. check out the review...If you really have no other option, its fair at best
post #9 of 10 (permalink) Old 01-03-2014, 02:20 PM
ERod62's Avatar
Water dipped and continuous use on a bike two different evaluations.
Used older model from that brand on a Heritage didn't survived long. When took it apart corrosion all over exposed solder and gain pot. Poor sealer coating work, cheap low budget item for short run. Just my two cents.
ERod62 is offline
post #10 of 10 (permalink) Old 01-03-2014, 03:54 PM Thread Starter
laserman's Avatar
Yup I'm really cheap.
Looking at doing Diablo 2 and will be tapped out when done. Seen J&M Cadillac system in Laconia and it rocks. But truly feel its over priced. Listen to a lot of metal on bike so I want decent bass. Good speakers $200 x 2 and Decent amp $200 doesn't = 1000+. want loud for under $500 as highway speed usually at 3200-3400 rpm's. Guess the real question can it be done?
laserman is offline
NeverWet- using it to Waterproof Non Marine speakers Scootin General Off-Topic Discussions 14 03-21-2015 09:48 AM
Bazooka MAC6502B Marine Waterproof 6.5" Audio Speakers Black laserman Audio 8 01-05-2014 08:33 AM
1000 watt J&M amplified System amorgan13 Audio 83 06-05-2013 04:25 AM
Hidden Amplified Antenna Install - 2011 RGC wachuko Do-IT-Yourself 10 10-28-2011 12:34 PM
Looking for a MP3/Ipod holder riccardo_21 *General Road Glide Discussions/Pictures 11 12-09-2010 09:46 AM
