New HEad unit in old bike - Road Glide Forums
post #1 of 11 (permalink) Old 01-03-2014, 01:17 PM Thread Starter
scayne62's Avatar
Will a newer HK head unit fit in an '02 RG without mods and everything work (hand controls etc.)?
No better way to see the world than outta the cage and in the wind.
02 RG Luxury Rich Red
12" KW windshield
Bassani Exhaust
King Tour Pak
Stage 1
Sundowner Seat
Pretty shiney stuff
scayne62 is offline
post #2 of 11 (permalink) Old 01-03-2014, 01:46 PM
Venomized's Avatar
I dont think the RGs had the same problem the Batwings did as far as mounting depth of the radio, hence why the old radios stuck out on thw older batwings. So itll fit.
As far as everything working, that may be a whole other ball game. Not sure if they changed pinning on the radio plugs or not or if theyve been the same since 98 like most everything else on these.
'07 Pewter Pearl
Road Glide or No Ride!
Venomized is offline
post #3 of 11 (permalink) Old 01-03-2014, 01:50 PM
OKBigD's Avatar
go to Hawg Wired's web site. They offer an adapter to fit the newer radio in the older bike's. You might call Hawg Wired but it looks like they're saying 98 up is the same.....
http://hawg-wired.com/product_info.p...th/51/pPath/71
OKBigD is offline
post #4 of 11 (permalink) Old 01-03-2014, 02:25 PM Thread Starter
scayne62's Avatar
According to HD it will not fit I need to go aftermarket but I know there are people smarter than the stealer on here.
12" KW windshield
Bassani Exhaust
King Tour Pak
Stage 1
Sundowner Seat
Pretty shiney stuff
scayne62 is offline
post #5 of 11 (permalink) Old 01-03-2014, 03:56 PM
ERod62's Avatar
Unless have a great deal on the newer units after market will be cost effective, check biketronics they have plug and play set up.
Here more options.
http://www.eglidegoodies.com/id179.html
ERod62 is offline
post #6 of 11 (permalink) Old 01-03-2014, 05:00 PM
torqu's Avatar
Biketronics has the cheapest install for these bike. They can be had for $50-$70.
V-twin audio has the nicest install kit imo. They were on sale a few weeks ago. Go aftermarket, you'll be happy you did.
torqu is offline
post #7 of 11 (permalink) Old 01-04-2014, 01:57 PM
Big Daddy Recon's Avatar
yeah as long as they can push you twords something new they are going to say it won't work.
2008 Harley FLHTCUI (MABLE) 50k+)
2011 Harley FXDWG (TRADED) 10K miles)
2013 Harley FLTRX (LUCIFER)(DECEASED) last 3 of VIN = 666
Big Daddy Recon is offline
post #8 of 11 (permalink) Old 01-04-2014, 09:46 PM
Yes it will fit. I had a HK in my 2001FLTRSEI2.
Just took out the cassette player and installed the HK.
I never used the CD player in the tour pack so I don't know if that part works
with the HK?
I have two sitting at home, I went aftermarket in my 13RGC.
festus is offline
post #9 of 11 (permalink) Old 01-05-2014, 10:07 AM
with the HK?
Festus, was there any rewiring needed ? Did all the switches on the handlebars work correctly?
LoneEagle
Eagle is offline
post #10 of 11 (permalink) Old 01-05-2014, 03:23 PM
Handlebar switches worked.
Don't remember if AVC worked?
festus is offline
Should I get new head unit? Perlinal Audio 7 03-16-2014 03:03 PM
Problem Installing New Head Unit RedDogNC Audio 9 02-13-2014 08:32 PM
Suggestions wanted: new head unit HellInABucket Audio 21 06-24-2013 08:52 AM
Old is new again, caused by being old... petewerner New Members Welcome Area 49 02-19-2013 09:46 AM
Improvement with new head unit? firstborn Audio 19 05-18-2012 10:21 AM
