Mounting amp - Road Glide Forums
post #1 of 12 (permalink) Old 01-03-2014, 03:32 PM Thread Starter
Venomized's Avatar
Mounting amp
Is industrial velcro enough to hold the amp in place if I mount it on one of the sides of the inner fairing slightly tucked behind the glove box? It wont fit on the radio clear the fairing.
'07 Pewter Pearl
Road Glide or No Ride!
Venomized is offline
post #2 of 12 (permalink) Old 01-03-2014, 04:10 PM
ERod62's Avatar
Think the glue will give up with amp heat and weight. Using the J&M 4 ch amp like the plate design may can fabricate one from stainless or aluminum plate.
ERod62 is offline
post #3 of 12 (permalink) Old 01-03-2014, 04:10 PM
fragmentum's Avatar
I wouldn't trust velcro to hold ANYTHING on the inside of the fairing! doesn't the amp mfg'er have a mount plate for your bike?
Make a mount plate to mount your amp like that for Hogtunes amps. I think you can buy a plate from them....
If your not living on the edge, you're taking up too much room...
fragmentum is offline
post #4 of 12 (permalink) Old 01-03-2014, 04:33 PM
neverdone's Avatar
Hogtunes and hawg wired sell them. I like the looks of hawg wired.
neverdone is offline
post #5 of 12 (permalink) Old 01-03-2014, 04:44 PM
Hawgwired started selling a mount within the last year, however, I've been using velcro since 07 with no problems.
Sent from my SPH-L710
post #6 of 12 (permalink) Old 01-03-2014, 04:44 PM Thread Starter
Venomized's Avatar
Just ordered the Hawg Wired plate instead.
'07 Pewter Pearl
post #7 of 12 (permalink) Old 01-03-2014, 04:59 PM
thedude's Avatar
3m makes a product called a hook and loop fastener, or something like that. I mounted my Hawg Wired amp in the fairing two years ago has not come loose yet. It is kind of like velcro but more heavy duty. I used it to mount the first amp I had and difficult time removing it.
thedude is offline
post #8 of 12 (permalink) Old 01-03-2014, 05:24 PM
sloride's Avatar
I have installed over 20 HW amps with their Velcro and never had one come loose
sloride is offline
post #9 of 12 (permalink) Old 01-03-2014, 05:34 PM Thread Starter
Venomized's Avatar
Im mounting a Soundstream pn4.320 but the HW plate looks good and will keep the install clean.
'07 Pewter Pearl
post #10 of 12 (permalink) Old 01-04-2014, 09:09 PM
Turk05's Avatar
Velcro will work just fine...
Turk05 is offline
Mounting bracket for Adjustable Rider Backrest Mounting Kit Part Number 52596-09A Oldbie Wanted! (Buy or Trade) 0 08-03-2017 09:24 PM
J&M Speakers & grills & mounting bracket ksarauer Parts for Sale 3 04-29-2016 04:02 PM
Mounting Radio Retro & Amp ? rookie racer Audio 1 04-24-2015 01:43 PM
'10 rider backrest & mounting kit BayouBob Classifieds Archive (3 months old+) 3 06-08-2011 09:53 AM
Mounting Amp gja Do-IT-Yourself 6 11-12-2010 05:25 PM
