charging issues? - Road Glide Forums
post #1 of 5 (permalink) Old 01-09-2014, 08:18 AM Thread Starter
charging issues?
Ok so I see a ton of people putting like 2 or 3 or even 4 amps in their RGC's...
The question is how many items drawing on the bike's stock alternator can you put in before you need to upgrade it?
I have 2 amps now in mine and was thinking about adding additional speakers to the lowers which could require another amp? or upgrading my 2 amps to larger ones (which would also draw more power....LOL)
Anyone?
mjohnson68 is offline
post #2 of 5 (permalink) Old 01-09-2014, 09:44 AM
JacktheBagger's Avatar
I'm not certain but I believe the stock alternator is around 55 amps , shud be able to put a bit of stuff to it , I don't know that there is an upgrade for the alternator
JtB
2011 Ultra
JacktheBagger is offline
post #3 of 5 (permalink) Old 01-09-2014, 09:56 AM
sfcusaret2004's Avatar
Sparks
Kinda hard to tell from the web but the highoutput alternator is listed at 54 Amps and the site says the FLTRU comes stock with the ho alternator so not sure if this helps but lok around I'm sure there are more knowledgable folks on here.
sfcusaret2004 is offline
post #4 of 5 (permalink) Old 01-09-2014, 10:51 AM
Harley came out with a HO stator kit this year, also Cycle Electric has a HO kit. I'm running 4 amps ( Hawgwired 3 CS300s and 1 RS400), I haven't had any issues yet, except I know a lithium battery isn't up to the task, but if I do have an issue I'll look into upgrading, most likely from Cycle Electric.
Sent from my SPH-L710
post #5 of 5 (permalink) Old 01-10-2014, 06:48 AM Thread Starter
Thanks for the info... I might be running the same amps. I have 2 CS300's now and am looking to add more but haven't looked into a bigger battery... I might have to check into that as well...
Mike.
Charging system issues Gngraham Troubleshooting for Road Glides 16 02-13-2015 11:41 AM
iPhone 4S - Charging/Not Charging dinggus Audio 8 11-01-2013 08:25 AM
Charging Issues - Voltage Reg AGAIN?! TracknTail Troubleshooting for Road Glides 3 10-07-2013 11:04 PM
Possible Electrical Charging issues??? paco ritter Troubleshooting for Road Glides 5 10-05-2012 09:26 PM
Charging issues with 2011 RGU? bobzilla Road Glide Specific Discussions 12 07-20-2011 05:59 PM
