Lowers on 110th anni RG - Road Glide Forums
post #1 of 12 (permalink) Old 01-13-2014, 09:21 AM Thread Starter
Hey guys,
few questions, researched and talked to Stealership and a price tag of 1000 turned into 2000,
so trying to do lower set up on my RGC 110th anni, with speakers
Was told Hog tunes woofer set wont clear my stock heavy breather (with long filter) so was going to go with shorter filter, was then told that I will still rub. I know it will be tight fit, but has anyone tried this and can say for sure it wont work?
Also was told the lowers wont get painted by harley, they will be painted by a third party that they deal with.. so my bike will need to be in the shop to allow for the painter to match the paint.. was also told there are no pin strips on the lowers for my bike...
2013 CVO Road Glide 110th Anniversary edition.
Anniversary Diamond Dust and Obsidian with Palladium Graphics. Screaming Eagle Performance Exhaust.
:Ride Till I Die:
2013-CVO-110RG is offline
post #2 of 12 (permalink) Old 01-13-2014, 10:32 AM
93-331-29psi's Avatar
Why isn't Harley getting you paint matched lowers from the factory? Sounds like they are trying to outsource it locally. Don't let them do that because there's a 95% chance that the paint WON'T match.
93-331-29psi is offline
post #3 of 12 (permalink) Old 01-13-2014, 10:48 AM
GlideShark's Avatar
Agree, get Harley to do it. Or hope for best. I have seen some look good and others, the difference was obvious.
As to the stripe on the lowers, that is correct as I have been told and seen on the road. The lower paint on the upper fairing is used. In my case, my lowers being painted starburst black (no white pearl).
I did see a member here that recently had 3d party paint his lowers to match the scheme on the upper fairing. Looked sharp. Cat whiskers and all from the 13s.
Sent from Motorcycle.com App
GlideShark is offline
post #4 of 12 (permalink) Old 01-13-2014, 12:55 PM
Agree on getting painted parts from HD. Your heavy breather with the long or compact filter will not work with fairing lower speakers, you will need to go with a different air cleaner set up. Check with PC Pain for the best prices on HD and aftermarket parts, he will save you a lot of money compared to your local dealer.
post #5 of 12 (permalink) Old 01-13-2014, 04:51 PM
GlideShark's Avatar
+1, I forgot to add that. I went with RSD nostalgia Venturi to match my horn but lots of nice ones out there.
post #6 of 12 (permalink) Old 01-13-2014, 04:53 PM
GlideShark's Avatar
Thanks Ironmark, I forgot to mention that swap would likely be necessary.
post #7 of 12 (permalink) Old 01-13-2014, 05:22 PM
skratch's Avatar
Originally Posted by 2013-CVO-110RG View Post
Hey guys,
too much money. i had joe from xtreme dimension (http://www.xtremedimension.com/) paint my lowers for me. i had the denim black ones left over from my 2010. the stock harley lowers for the 2013 cvo is a solid burnt emerald. he would have done that for $350. but i decided to go with the 'themed' paint, which was a lot more work, that was $600. the burnt emerald set were over $800 from harley.
i have the shorter filter on mine now. it absolutely will not fit with speakers. not and still look good anyway. you can make anything fit with a knife
you can also find xtreme dimension on facebook
note that there is only about 1/4'' clearance between the filter end and the door here:
and this is just a better pic of the lowers :
skratch is offline
post #8 of 12 (permalink) Old 01-13-2014, 05:34 PM
GlideShark's Avatar
I knew I wasn't crazy. Looks good Skratch.
post #9 of 12 (permalink) Old 01-14-2014, 06:46 AM
skratch's Avatar
thanks..
joe does great work. and if you already have lowers, or can get some cheap joe can hook you up with a great paint job. he can also do some kind of 'theme' to blend them in with the rest of your bike.
skratch is offline
post #10 of 12 (permalink) Old 01-14-2014, 07:49 AM
mocotom's Avatar
The CVO paint schemes are not an in-house Harley product, they are done by an outside vendor. It is very possible the dealer can not get the correct painted lowers for your year and that is why he stated they will need to use a third party painter.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
HD 110th/HOG 30th Anniversary Celebration Wildman *General Road Glide Discussions/Pictures 45 08-08-2013 12:24 PM
Milwaukee 110th party BigBlueShark Road Trip Discussions/Stories/Pictures 31 04-16-2013 07:54 AM
SOLD! 110th Anniversary collectible museum tin TracyB Sold 2 01-19-2013 09:59 AM
110th Anniversary Tank Medallian Freaky *General Road Glide Discussions/Pictures 14 10-13-2012 10:13 AM
Lowers, lowers and more lowers Garemlin *General Road Glide Discussions/Pictures 57 05-11-2010 09:18 PM
