XM antenna - Road Glide Forums
post #1 of 5 (permalink) Old 01-13-2014, 02:24 PM Thread Starter
XM antenna
Does anyone know of an XM radio antenna that works better than the stock, inside the fairing antenna? If so, is it any good? I ride a lot in places I don't get FM reception and often the mountains and trees interrupt my XM radio too.
Thanks,
Kudu40
Kudu40 is offline
post #2 of 5 (permalink) Old 01-19-2014, 01:13 PM
vbateman's Avatar
XM
I swapped to external as I would loose signal even going under overpasses.
Cost me $50 but now much happier
vbateman is offline
post #3 of 5 (permalink) Old 01-19-2014, 01:33 PM
ERod62's Avatar
Nothing beats the stick. Try two best proclaim fairing antennas both poor receptions.
Sent from Motorcycle.com App
ERod62 is offline
post #4 of 5 (permalink) Old 02-20-2014, 07:40 PM
Roadglide Charley's Avatar
Hey I have a 13 cvo. How hard to add xm? Sick of the lackluster radio reception
Roadglide Charley is offline
post #5 of 5 (permalink) Old 04-24-2014, 01:07 PM
Hey Roadglide Charley
Have you found a way to add XM without the Handlebar mounted unit? I have been looking into this also. I either have to find an antenna that works or find a way to add the XM without changing head units.
jack
hawkeye4jw is offline
WTB - GXM40 Antenna - Garmin XM Radio gakarl Wanted! (Buy or Trade) 1 08-26-2013 04:07 PM
Garmin XM Antenna Puck placement rrs49 Equipment-RG 10 06-03-2012 04:34 PM
Best place to put XM Antenna? Adam6946 Audio 9 05-15-2012 10:36 AM
Check Antenna - XM Module Speedie Audio 1 03-31-2012 10:01 AM
XM antenna location ? spender9 Audio 3 06-12-2011 04:26 AM
