PBR 300x2 vs JM 250 amp kit - Road Glide Forums
post #1 of 12 (permalink) Old 01-15-2014, 09:49 AM Thread Starter
hometoast's Avatar
PBR 300x2 vs JM 250 amp kit vs SoundStream pn2.350
I already have the JM Rokker XX speakers, not yet installed.
The JM amp runs just shy of $400.
The RF amp is under $150.
Is there any compelling reason to spend the extra $250 on the JM amp?
[s]Or would the Soundstream Pn4 work as well, but that's for 4ohm speakers.[/s]
Or the SoundStream Soundstream PN2.350D for $115
hometoast is offline
post #2 of 12 (permalink) Old 01-15-2014, 09:57 AM
Venomized's Avatar
The rockford and soundstream can both run 2 ohm speakers. I currently have the PN4.320 running 2 ohm Infinity 62.9i 6.5s.
On the pbr and PN your gonna get a higher power output running 2 ohm.
'07 Pewter Pearl
Road Glide or No Ride!
Venomized is offline
post #3 of 12 (permalink) Old 01-15-2014, 10:07 AM Thread Starter
hometoast's Avatar
So it sounds like the soundstream will get me what I want/need at $115. I understand if I want to add lids or another pair in the faring, I'd have to change equipment. But that doesn't seem likely.
post #4 of 12 (permalink) Old 01-15-2014, 11:11 AM
Venomized's Avatar
If your running a 4 channel soundstream (4.320/4.520) then you can still add another set without having to swap or add amps. You can run just the two front channels (like I am currently) and keep the rears open for expansion later on. Each channel is stable to 2 ohms so your safe.
'07 Pewter Pearl
post #5 of 12 (permalink) Old 01-15-2014, 12:12 PM Thread Starter
hometoast's Avatar
Thumbs up
Thanks a bunch. If the JM's are rated 200W+ max, would the pn2.320 (175w ea) deliver better for them than the 4.520 would (130w ea)?
post #6 of 12 (permalink) Old 01-15-2014, 01:53 PM
Venomized's Avatar
Seeing that JM mates them with their amp that only pushes 125 rms either would work fine. I hace a hard time believing those things can handle that much power though.
'07 Pewter Pearl
post #7 of 12 (permalink) Old 01-15-2014, 01:58 PM
OKBigD's Avatar
I just fired up my SS pn2.350D with Polk MM 651's.. I set my gains at half and with the Alpine 149bt turned up to 20 it is stupid loud...... Crystal clear but stupid loud....... The polk's say they handle 200W peak also......
OKBigD is offline
post #8 of 12 (permalink) Old 01-15-2014, 02:10 PM
Venomized's Avatar
My Infinity 62.9i are rated at 225 peak/75 rms and Im running them off the front channels of a Soundstream PN4.320 and gain set at right above half and they scream at 5 on the stock HK unit
'07 Pewter Pearl
post #9 of 12 (permalink) Old 01-16-2014, 07:12 AM Thread Starter
hometoast's Avatar
I totally agree, I wouldn't rely on MAX wattage for nearly anything.
I ordered the pn2.350D only because it's a bit shorter and I really don't plan adding speakers in the (near) future. PLUS, I had almost enough credit on my amazon account to cover it!
post #10 of 12 (permalink) Old 01-16-2014, 08:21 AM
RichieRich's Avatar
i'm editing this Richie-see above
Yeah I saw that thread disappear. Complete garbage. You aren't the first to complain about JM and I'm sure you won't be the last.
Sent from Motorcycle.com App
2013 BBP FLTRX
RichieRich is offline
Stock HU, RF PBR 300x2, J&M Rokker XT 7.25 roadie13 Parts for Sale 5 03-16-2015 07:19 AM
J&M 250 Amp question for JM John or anyone that has an answer AndyM Audio 7 01-27-2014 08:23 AM
J&M Rokker XTs and a RF PBR 300x2 FLhogger *General Road Glide Discussions/Pictures 3 05-19-2013 03:49 PM
Rokker XTs with PBR 300x2 & Ipod interface gfyoung3 Audio 6 04-21-2013 11:44 AM
Some RG mods including PBR-300x2 Amp install mrwatson Audio 14 04-09-2012 05:37 PM
