dissaster amp install - Road Glide Forums
post #1 of 19 (permalink) Old 01-15-2014, 09:50 PM Thread Starter
ironmike666's Avatar
Got the boom audio amp installed.
Just about had it back together, everything was cool.....all of a sudden cd sound shuts off. CD still playing but no volume.
take fairing off, sound resumes.
Put back together, try ipod....it works fine. accidentally hit signal and ipod volume cuts off intermittently with signal. Then stereo shuts off. What the heck!!!
Any help would be greatly greatly appreciated
Took amp out of equation...still does the same thing. Beginning to wonder if it was something that happened between the stage 4 kit install and the amp install. Havent had bike stereo on since last day I rode it....so cant really eliminate anything since then.
ironmike666 is offline
post #2 of 19 (permalink) Old 01-15-2014, 11:52 PM
Venomized's Avatar
What do you mean by accidentally hit signal??
Sounds like you have a loose connection somewhere.
Are your grounds all good and tight and clean?
'07 Pewter Pearl
Road Glide or No Ride!
Venomized is offline
post #3 of 19 (permalink) Old 01-16-2014, 03:22 AM
Big Daddy Recon's Avatar
+1
sounds like your haveing a loose connection in there that is getting pulled or pinched when you put the fairing on. make sure everything has wiggle room and the wires are all tight connections
2008 Harley FLHTCUI (MABLE) 50k+)
2011 Harley FXDWG (TRADED) 10K miles)
2013 Harley FLTRX (LUCIFER)(DECEASED) last 3 of VIN = 666
Big Daddy Recon is offline
post #4 of 19 (permalink) Old 01-16-2014, 05:50 AM
ERod62's Avatar
Originally Posted by Big Daddy Recon View Post
+1
Agree will start by checking all connections. If all works fine without the fairing most have lose plug wire etc.
Sent from Motorcycle.com App
ERod62 is offline
post #5 of 19 (permalink) Old 01-16-2014, 09:30 AM Thread Starter
What I meant by accidentally hit signal, was that I reached over the bars to turn volume up and accidentally turned on the signal light. That's when sound started to cut in and out.
It also does this with the fairing off.
Should the negative wire from amp be grounded or just ran to negative side on battery? Says battery in instructions
Will give all connections and grounds another good look tonight.
post #6 of 19 (permalink) Old 01-16-2014, 10:04 AM Thread Starter
Where are all the grounds? Found a couple by the battery. They're tight.
Beginning to wonder if its something in the controls/bars. Doesnt matter if fairing is on or off.
post #7 of 19 (permalink) Old 01-16-2014, 10:37 AM
hometoast's Avatar
This may be way off, but try it with the bike running, so that you can be sure the system is getting full voltage supplied.
hometoast is offline
post #8 of 19 (permalink) Old 01-16-2014, 10:50 AM Thread Starter
Anything is worth a shot. Thanks.
Actually had battery tender on last night....tried it today for a couple minutes and worked fine.
post #9 of 19 (permalink) Old 01-16-2014, 11:05 AM
OKBigD's Avatar
Where did you run the ground to? If it's to the frame make sure there's no paint or powder under it...
OKBigD is offline
post #10 of 19 (permalink) Old 01-16-2014, 11:24 AM Thread Starter
No ground. Just ran red to positive terminal and black to negative terminal.
AMP Install Power & Ground Wire Routing wevsspot Audio 4 05-08-2015 09:27 AM
Buky Malo install problems! Love the bars! Just a FYI on the install! bigshaqa *General Road Glide Discussions/Pictures 14 04-08-2014 01:37 PM
Daymaker Light Install - Install Problem - And Resolution Martin Lighting 22 06-06-2013 07:57 PM
Amp Install & HK Radio Warranty scooterroid Audio 5 08-30-2012 02:42 PM
amp & speaker install Trex69 Audio 2 07-17-2012 07:20 AM
