I Need a Little............ - Road Glide Forums
post #1 of 24 (permalink) Old 01-21-2014, 07:03 PM Thread Starter
Jwasielczyk's Avatar
Inner Fairing Speakers......I need a little......
Help/Balls.............haha. So here goes, I have 2 h-donut amp mounts, I will only use one now, but im installing both so that its there and not going to get lost in my misc HD parts, 1 RF PBR300x4, 4 RF power T165's 6.5", speaker reducers, and misc amp and speaker wires. I am having my buddy color match the speaker grills from the RF, and the speaker grills from hawg wired. The help I need is in regards to the "inner fairing" speaker install.... Any guys running the power T165 in the inner fairing??? what are your measurements on the cuts you made to the fairing, I don't want to lose my pockets.....Man am i nervous about cutting into my fairing.... I have included a few pics of my own bike, then a PYO bike that is close to mine and will give you an example of what im going for in my speaker install..... When i get started ill take some pics and post as well......Since its winter i have some time and i can bounce from the shark to the ShovelHead Wide Glide(engine rebuild with some minor "tweaks")....
Jwasielczyk is offline
post #2 of 24 (permalink) Old 01-21-2014, 07:05 PM Thread Starter
And..
This is the PYO Bike......
post #3 of 24 (permalink) Old 01-21-2014, 07:32 PM
Sending you a PM.
post #4 of 24 (permalink) Old 01-21-2014, 07:39 PM Thread Starter
DBell
Replied to PM
post #5 of 24 (permalink) Old 01-21-2014, 07:53 PM Thread Starter
So Dbell sent me the PYO pics, but ...... are there supposed to be some sort of measurments with them?
post #6 of 24 (permalink) Old 01-22-2014, 04:43 AM
stripclub's Avatar
There are no measurements with them, but they do show a good location for the cutouts, I used the same RF speakers that you are using, and didn't loose the boxes, but if you use the RF grills, the upper bolt on each side of the fork tubes wil need to be changed out for a little added clearence, I used chrome hex button head, and gained the extra little I needed.
stripclub is offline
post #7 of 24 (permalink) Old 01-22-2014, 05:00 AM
stripclub's Avatar
This is a couple pics of my inner, hope it helps.
post #8 of 24 (permalink) Old 01-22-2014, 08:19 AM Thread Starter
StripClub.....The pictures do help, Does anyone else have any pics, or measurments on this kind of install..... Again i am wanting to cut inner fairing for RF T165 power series..... What size hole do you cut?.....I just quickly flipped through the RF speaker book , but i did not see a "template" I will check again after work.....I should have the rest of my goodies when i get home,,,,, Then i am shipping the grills off to paint, when i get them back look out..... Is it easier just to remove the inner fairing? how hard is this to do???? I have removed the outer fairing a few times but i have never removed the inner........
post #9 of 24 (permalink) Old 01-22-2014, 08:50 AM
stripclub's Avatar
I did mine on the bike, I removed the outer fairing, and the gas tank, tapped the inner fairing up where I wanted to put the holes. I made my own templets up out of cardboard, I used the speaker grill as my outer diameter, and cut the center hole of the cardboard out so the speaker would just fit inside, and used that to marked out the holes, and used a Dremel with cutoff wheels to cut "actually more like burn/cut the plastic" for the speaker holes, it wasn't easy but can be done, the smaller tweeter holes in the front, I used a holesaw. I know it is hard to make the first cut, but once it is done, it is so worth it.
post #10 of 24 (permalink) Old 01-22-2014, 09:40 AM Thread Starter
Thats a good idea to use the cardboard, how do you get the 4 screw holes in there working around the glove boxes, also did you cut from the inside or out? Do you think the "burn" will affect my painted inner?
Little By Little - Bar Replacement in Process.... JDisMe Controls & Handlebars 19 07-23-2017 10:50 AM
need a little help finding my rear speaker wires mroach Audio 3 03-18-2012 08:30 AM
Need A Little Lighting Help anubus201 Lighting 8 02-27-2012 04:12 PM
Need a Little Help Here.....Please, Pic Nevadasun *General Road Glide Discussions/Pictures 12 01-16-2012 09:54 AM
Need a Little Help InMotionJosh *General Road Glide Discussions/Pictures 6 10-18-2011 12:28 PM
