J&M 250 Amp question for JM John or anyone that has an answer - Road Glide Forums
post #1 of 8 (permalink) Old 01-25-2014, 11:37 AM Thread Starter
AndyM's Avatar
Hey JM John, I had a J&M 250 installed some time ago by a local stereo place and connected to the Boom speakers I was running at the time. I just now purchased a new set of JM Rokkers XX 7.5's and installed them.
Was I supposed to do anything like adjustments or tuning?
12 FLTRX BBP SERT SE A/C V&H Power Duals & V&H HO Slip-on's + a few more goodies, Andrew's 37H = 99 HP & 110 Torque (after a proper tune at Pensacola HD)
AndyM is offline
post #2 of 8 (permalink) Old 01-25-2014, 11:56 AM
ERod62's Avatar
J&M amps ship tuned for their speakers. Both speakers rate at 2 ohms don't need to.
Sent from Motorcycle.com App
ERod62 is offline
post #3 of 8 (permalink) Old 01-25-2014, 12:33 PM
GlideShark's Avatar
You should be good to go. Specific amps, because pre-set, should be bought for different configurations. Ex: adding lower speakers v adding speakers in bag.
GlideShark is offline
post #4 of 8 (permalink) Old 01-25-2014, 03:25 PM Thread Starter
AndyM's Avatar
Thx guys. Well, I bought the Amp from a member on HD forums and like I said, I installed it some time ago when what I had were the Booms so I'm not sure how it was configured to begin with, I suppose I'll have to go back to the shop and have them look at it.
AndyM is offline
post #5 of 8 (permalink) Old 01-25-2014, 03:34 PM
JayKS's Avatar
I don't think you would have to adjust the gains, but it certainly wouldn't hurt.
Here's how you do it:
JayKS is offline
post #6 of 8 (permalink) Old 01-26-2014, 11:41 AM
RedDogNC's Avatar
If the amp's controls are covered by a tape that says something about voiding the warranty if touched then it is set to work with an HK Head Unit and J&M speakers from J&M. If your amp does not have the tape covering the controls then there is no way to really know since the other guy could have messed around with them. Use the previous link to make adjustments yourself. Their levels are set so if you push the Head Unit all the way to level "10" the sound won't be distorted enough to do damage to the speakers.
[/SIGPIC]Wife and I on our Anniversary Ride July 2015 Highway 128 going through Anderson Valley on the way to Mendocino. Her ride is the 15 RGS. My old 09 RG is shown. Now I have a red 16 RGS.
RedDogNC is offline
post #7 of 8 (permalink) Old 01-26-2014, 11:15 PM
That's Right! Just hook up your stuff using best practices, be easy on the volume, and pay attention to sound quality (distortion) as you are increasing the levels...
HeatWave is offline
post #8 of 8 (permalink) Old 01-27-2014, 08:23 AM Thread Starter
AndyM's Avatar
Thx all. JM John has also responded on this on a thread on another forum and has been helpful as well. Thx again to all who responded.
AndyM is offline
Question for JM John Quicksand Audio 5 05-12-2016 10:22 PM
PBR 300x2 vs JM 250 amp kit hometoast Audio 11 01-17-2014 06:16 AM
Dumb question deserves an answer pisssed Windshields 2 02-01-2011 05:46 AM
